Results 1 to 14 of 14
Thread: New Vulcan Protig 205 - flows gas but no arc??
    Apr 2021
    I purchased a Vulcan ProTig 205 set it up and it turns on, when I step on the pedal I get gas flowing through the torch but no arc. I have tried AC and DC but no luck. Any ideas?
    Sep 2016
    Detroit, Michigan
    Re: New Vulcan Protig 205 - flows gas but no arc??
    Does the HF fire at all? It probably won't help, but I'd try scratch starting it....hit the pedal then swipe the tungsten off the work piece. If you still don't get an arc I'd just take it back for a replacement. Actually, that's probably what I would do either way, but it would be interesting to know if it will actually produce an arc.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Apr 2021
    This is actually the second one, they both did the same thing so it must be something I am doing wrong.
    Sent from my SM-G950U using Tapatalk
    SoCal-LA
    I have not had mine turned on in weeks. Check and see if there is a preflow window. If so it may have a very long preflow. Then see if you can turn it down. Then if you turn it down, power the machine off and see if it remembers. My employees mess with my Dynastys on occasion and wreck the preflow setting.
    Apr 2021
    The preflow window is set to 0.3 seconds and post flow is set to 3 seconds.
    Laredo, Tx
    Is the work clamp hooked up? Pics of everything would really help.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Apr 2021
    Yes the clamp is hooked up. I even tried touching the torch directly to the clamp. I will add pics tomorrow.
    SoCal-LA
    Quote Originally Posted by 1StopJeff View Post
    Whoa, 3 second post flow is too little.
    SoCal-LA
    I guess I would power the machine up, strike an arc in the air, then let the post flow run out. Touch tungsten to the metal and lift some 1/16" and hit the pedal. If you are trying to lift arc, the machine will not let you do it. And if the machine will not light up with a gap, it will also turn itself off. That is a self protection feature.
    By the way, I really hate the pedal. Used it a few weeks ago on a gate build and standing on the pedal is almost impossible.
    Apr 2021
    It wont strike an arc in the air, it wont arc anywhere. I am running a 75/25 argon/CO2 mix, could that be the issue? This is so weird to have 2 units do the exact same thing. I have tried it on 220v and 110v and it acts the same way. https://uploads.tapatalk-cdn.com/202...ac78f7d24d.jpg
    Sep 2016
    Detroit, Michigan
    I don't know if the gas will prevent an arc from starting, but you can't TIG weld with 75/25. You need 100% argon....you can use helium or helium/argon blends, but they're expensive and not something a beginner needs to worry about.
    http://mivise.com
    Apr 2021
    I'm having the exact same problem with the protig 205. This is the second one that did this this week. I had the first on for almost 2 months with no problems under daily use. I returned it and got a replacement and 2 days later, I have the same problem. I assumed that I was using it too long for the duty cycle on the first one, so was very careful not to use it for more than one pass without giving it a 10 minute break while running ac tig at 170. After about 6 2inch passes it died last night again. I checked all the wiring, ground a new area for my grounding clamp to make sure it was properly grounded, tried scratch starting it and still nothing. After attempting to scratch start it the machine screen started to blink on and off continuously until I turned it off and on. Pressed the reset button and still nothing. This one won't create an arc at all, but the last one would make a inconsistent chattering arc but not strong enough to weld with. This is a major problem for me because I use this welder to run my business. I'll return it today and get another one and hopefully this will be the last time I have a problem. I'm definitely going to leave a this exact same review on the harbor freight website.
  13. Likes California liked this post
  14. #13
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by Dashwelding View Post
    I sure wouldn't bet my business on that. At the very least I would dump that HF machine and get a Primeweld 225....you don't see review after review with them not working out of the box, breaking after only a handful of uses, etc. Honestly, I wouldn't even trust that level of machine for business use, but they seem to have far fewer problems than the other cheap imported machines.
    http://mivise.com
  15. #14
    Dec 2003
    Fairfield,CT
    When are you people going to learn after the first one get your money back and go elsewhere. I got a DOA one and had to argue to get my full refund back. They wanted to charge me a restocking fee. NOPE I would not accept that.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
Page generated in 1,623,832,574.32186 seconds with 12 queries
