Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 345
Thread: Shootr's New Adventure - Totem Pole Build
  1. #76
    Re: Shootr's New Adventure - Totem Pole Build
    As for the gap, adding a rod is fine. That's usually called, slugging.
    If you using stick, 6010 or 6011 will work to fill it. They both are fast freeze rods. Depending on skill level, you can move rod into puddle, blackout, so puddle cools, and then move back in.
    Mig is even easier, just turn machine down.
    Once filled, depending on how you did, reset machine and run over it.
    It maybe easier to grind high spots and then run over.
  2. Likes psacustomcreations, Shootr, Lis2323 liked this post
  3. #77
    Fredericksburg, VA
    Bob's method is how I would do it. Use a piece of a welding rod, scrap rod, etc and bend it to shape to mostly fill the gap between the ears and head. Then run over it with MIG. You could even run over it with TIG if you want.
  4. Likes Shootr, Lis2323 liked this post
  5. #78
    Filler rod is likely the easiest option at this point if you aren't happy about the gap... another would be to spend a little more quality time with the grinder to make the fitment closer before tacking. You will still see a crack or joint however...
    Arizona
    Taking a lunch break and watching the Indy 500. The rod worked well - my welding skills...let's just say I'm still the poster child for "grinder and paint make me the welder I ain't".
    After three passes with grinding in between got it to where I'm happy enough. Got the eyes done too. This afternoon is the angry eyebrows lol.
    Thank you all again (and again) for advice and guidance - I'm thinking/hoping this may be one of my better efforts.
    Yeswelder MIG-205DS
  7. Likes psacustomcreations, whtbaron liked this post
  8. #80
    I might get shot at for saying this on a welding site, but if you're going to grind and paint it anyway, JB Weld is a lot easier to grind....
    Arizona
    More progress this afternoon. Got a lot of the mouth done (that's not it's final place). Should finish it and the nose up tomorrow - the nose should pull it all together - the piece on there now is just a place holder.
    I thought I kept the work are pretty squared away - but the polishing wheel has other ideas...
    Yeswelder MIG-205DS
  11. #82
    [QUOTE=Shootr;8815239]More progress this afternoon. Got a lot of the mouth done (that's not it's final place). Should finish it and the nose up tomorrow - the nose should pull it all together - the piece on there now is just a place holder.
    I thought I kept the work area pretty squared away - but the polishing wheel has other ideas...
    As for polishing and grinding, a die grinder is really nice for artwork. I bought the Metabo variable speed compact die grinder at add with my old Milwaukee die grinder.
    The variable speed is definitely worth having. Wire wheels last a lot longer using at slower speeds. It's great for polishing too.
  12. Likes 12V71, Shootr, whtbaron liked this post
  13. #83
    Arizona
    Aaaaaand - finished!
    I think my practicing is starting to pay off:
    I used cold blue to darken some of the features. Hard to get a good pic in the sun showing it though.
    I learned a lot on this one. Very pleased with the result. Time for a break and figure out what the next one will be. I know the top piece will be an eagle, just have find something that turns me on for the middle.
    Yeswelder MIG-205DS
  14. #84
    Arizona
    I think I'm going to have to lose the smoking spirit for this project. I think the bears came out so good (IMO) that I want to keep it more traditional and the bottom one just doesn't fit.
    Maybe I'll cut a hole in the top of his head, weld in a hemisphere - and sell it as an ashtray!
    Also last night it came to me - a moose. I think a moose would fit with the Pacific NW vibe, and be a little humorous as well. Soo Bear, Moose, Eagle - I still need to decide on a 4th.
    Yeswelder MIG-205DS
  15. #85
    Jan 2015
    Martha Lake, WA
    Shootr, the new addition looks great! I'm from the Pacific Northwest and your piece would look at home here in the land of totems.
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
  16. Likes Shootr liked this post
  17. #86
    Arizona
    Quote Originally Posted by jrporter View Post
    Right on, thanks! I am tickled with how it came out and hope the next one's are a little cleaner each time.
    Yeswelder MIG-205DS
  18. #87
    Arizona
    [QUOTE=BD1;8815269]
    I have 1/4" electric die grinder - it's a little unwieldy but I get by with it. I also have an 1/8" flex shaft rotary tool - I really used that a lot on this one and like it as well.
    This weekend I'm going to dig into the smoking spirit. Cut a hole in the top for a stainless bowl to sit as the ashtray, along with cigar rests around the perimeter. On the back of the head I'll make a steel "pocket" to hold a lighter and cutter. Next, I think I'm going to add a large brim to the hat - big enough to set a couple glasses of scotch on lol. Lastly I will go over the whole thing with scotchbrite discs and clear coat it.
    I think it will be cool - we'll see what the market thinks.
    Yeswelder MIG-205DS
  19. #88
    Fredericksburg, VA
    [QUOTE=Shootr;8815629]
    Maybe use the small propane torch to heat up some areas of the smoker to add color?
    If you are careful, you can get some nice straw color all the way to dark blue.
    Then apply the clear coat.
  20. Likes whtbaron, LtBadd, Shootr liked this post
  21. #89
    Feb 2016
    Oregon
    I don't think I've ever seen a moose in western Oregon, but in Anchorage AK, you can see them in your back yard as a friend of mine has.
  22. Likes Shootr liked this post
  23. #90
    Arizona
    [QUOTE=psacustomcreations;8815650]
    I like that idea. I have been staring at it and trying to figure out where it would be good to do.
    Do I just try random splotches or stripes, or try to make it look like clothes?
    All I've come up with so far is to color the top and soon to be brim so it stands out more like a ball cap. Maybe the arms and legs to look like sleeves and pants?
    Yeswelder MIG-205DS
  24. #91
    Arizona
    Quote Originally Posted by PDXsparky View Post
    On a fishing trip we drove from Fairbanks to Valdez and saw a bunch along the way - I can certainly see how they kill people and total cars - much bigger than most people think.
    Yeswelder MIG-205DS
  25. Likes whtbaron liked this post
  26. #92
    Fredericksburg, VA
    [QUOTE=Shootr;8815721]
    I would probably darken the areas where the arms and legs join the body. Then leave the tops or middle parts lighter. That would help to create some contrast like it is in shadow.
    While I was initially thinking you could use that to create the chin/beard or differentiate between the mouth and knees, I am second guessing that.
  27. Likes Shootr liked this post
  28. #93
    Arizona
    I got most of the parts fabrication done this morning - when it hit 107 around noon - that was enough for this day.
    I cut a slot for the brim to slide into and it's nice and stiff. Scared to death of trying to run a decent looking bead all the way across the joint. Thinking of a couple tacks underneath, and maybe an 1/8" rod bent to cover the joint and tacked at each end.
    I should be able to finish it up tomorrow - liking the progress though!
    Yeswelder MIG-205DS
  29. Likes Lis2323, 12V71, wb4rt, whtbaron, VaughnT, LtBadd liked this post
  30. #94
    Me too!
    107 ugh. No thank you
  31. Likes BD1, Shootr liked this post
  32. #95
    I’ve used round , flat stock , and even small angle to conceal a gap or opening.
    Form to fit and only tack on ends where it can be blended by sanding or grinding.
    I’ve used multiple round stock thicknesses
    to give a different look too.
    Forming small angle gives a nice appearance too. It depends on what you prefer.
  33. Likes Shootr, Lis2323 liked this post
  34. #96
    I really like that "end table", Shootr. Everything about it is just perfect, and I can easily see someone wanting that for their cigar bar or man cave.
    Looking at it, I think I prefer the hole-in-the-head technique for joining the two pieces, too. While the bearing race works, I think the big gap that it leaves takes something away from the flow of the two sections. With the hole in the head, though, the top section would sit down a little deeper and look more like the whole thing was carved from one steel log.
    Next time I find some old gas bottles.....
  35. Likes Shootr liked this post
  36. #97
    Arizona
    Thanks! I agree with the stacking comment - even though "the smoker" is no longer destined to be part of the totem pole, future spirits will be mounted much closer together. I've had some buddy's offer great suggestions on the hat brim: Stick rods with no flux because they look like tiny rope (like Pat and BD1 noted earlier), twisted copper wire to look like braiding, etc. It's 9am, 96 degree's, and time to get to it!
    Yeswelder MIG-205DS
  37. #98
    Good ideas for filling the crack
    I will need to remember that. Thanks, guys
  38. #99
    Nice work shooter, I am very impressed. Do you plan on putting some heat on it to add any color, keeping it shiny steel and clearing over or just letting nature have at it with rust in hopes it will darken and almost look like wood? There are chemicals you can use to stain the metal to specific colors but I don’t know much about them. Perhaps other members can share what they know. Looks good man keep it going
  39. Likes Shootr liked this post
  40. #100
    Arizona
    Heck yeah!
    Really stoked with how it came out. Final touches include a pouch on the back for lighters and cutters, heat "staining" the arms, toes, and hat brim, and clear coating after I ran over it with a 120grit flapper. I cut up a stainless steel pipe and shaped them into cigar rests, then welded them to a common stainless steel salad bowl for the ashtray.
    Practice, practice, practice...
    I'm thinking in the $400-$500 range - guess I'll see.
    Yeswelder MIG-205DS
  41. Likes 12V71, VaughnT, LtBadd liked this post
Page generated in 1,713,273,714.12693 seconds with 22 queries
