Results 1 to 25 of 28
Thread: Can I use #1 AWG welding cable for Dialarc HF ?
    Feb 2021
    NY
    Hi everyone,
    I want to put new leads on my Dialarc HF. Its a 1979 model and max amps of 310. I only use it for stick and mostly run 5/32 7018 and 6010. I only need about 20 feet and usually run under 200 amps. I do not plan on welding aluminum or using AC.
    I am also going to add Tweco adapters for the lug type terminals and use dinse connectors.
    Thanks in advance
    Mar 2005
    Under a Rock
    Re: Can I use #1 AWG welding cable for Dialarc HF ?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  3. Likes Jonath108 liked this post
    Mar 2021
    Near Roanoke, VA
    Look at an ampacity chart,, with your amps, and wire size,, expect a low duty cycle to keep the wire from heating.
    I would do it,, but, I never weld continuously,,
    https://www.lapptannehill.com/resour...ampacity-chart
  5. Likes Jonath108 liked this post
  6. #4
    Feb 2021
    NY
    Thanks,
    Looks like I should go for 1/0 just to be safe.
  7. #5
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by Jonath108 View Post
    Thanks,
    Why? 1/0 is good for up to 60% duty cycle at 350A as long as the leads are combined 50ft or less.....way more than what you're talking about. #1 is good for 60% at 300A so there is really no way you'd have an issue at 200A or lower. #1 is probably close to 100% at 200A with 50ft or less combined leads...and nobody can stick weld 100%.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  8. Likes Louie1961, Jonath108 liked this post
  9. #6
    Mar 2021
    Near Roanoke, VA
    Thanks,
    You will use a 1/0 cable seven times, then toss it in the corner because it is too heavy.
  10. Likes John T, Dave66, Louie1961, Jonath108 liked this post
  11. #7
    I suspect your welder would hit its duty cycle long before 20' of AWG #1 welding leads would.
  12. Likes Jonath108 liked this post
  13. #8
    CT
    I run 2 gauge on my syncrowave (which also goes up to 310 amps) and with short leads I have never had a problem.
  14. Likes Jonath108 liked this post
  15. #9
    Sep 2005
    Cave Creek AZ
    Number 1 is perfect for that machine. It probably has something like #4 on it from the factory.
  16. Likes Jonath108 liked this post
  17. #10
    Jan 2008
    Richmond, Virginia
    For your use, #2 should be more than adequate. If you are concerned, use a #1 work lead and a #2 stinger lead.
    I just had to move a big bundle of long 2/0 leads just a few feet. OMG heavy.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  18. #11
    Feb 2021
    NY
    When I called my LWS, they said #1, and both leads should be the same , as in #1 leads.
  19. #12
    Upsell!
  20. #13
    Feb 2021
    NY
    Are all welding cables about the same, or is their a brand that is superior ?
    Thanks
  21. #14
    Sep 2016
    Detroit, Michigan
    Thanks
    There are some that are better than others. The quality of the jacket matters and the higher strand count the better...both lead to more flexible cables. I stay away from the imported cables....tends to be lower quality, and more importantly....it often stinks! Quality cable made in the U.S. can be quite flexible and actually smells nice.
    I've bought from this company many times...they're local to me, but sell on eBay and I think Amazon.
    This is for their red #1 cable, but they offer it in black and probably have a set with 20ft of black and 20ft or red if you look through their listings.
    https://www.ebay.com/itm/1-AWG-EXCEL...MAAOSwhOVXe9vP
    http://mivise.com
  22. Likes Jonath108 liked this post
  23. #15
    Sep 2005
    Cave Creek AZ
    Go feel it before you buy. I bought a hundred feet of 1/0 to extend my leads for a job. This was during the copper crisis ten years ago or so. I paid a premium for it because only Praxair had it in stock. It is the stiffest welding cable I have ever had. It never gets used unless I need the extra feet.
  24. Likes Jonath108 liked this post
  25. #16
    Hellinois
    Go to www.electronbeamtechnology.com
    I buy all my lead from them. Excellent quality, great prices.
    "Stick-man"
  26. Likes Jonath108 liked this post
  27. #17
    Feb 2021
    NY
    Good advice, thanks.
  28. #18
    Feb 2021
    NY
    Thank you
  29. #19
    Feb 2021
    NY
    Does anyone know the exact tweeco adapter for a older Dialarc hf with 1/2 studs at the terminals. I would like quick connects on both leads where they connect to the welder.
    Thanks in advance
    J
  30. #20
    Hellinois
    Thanks in advance
    J
    If you want quick connectors, look at the following. These are compatible with the popular 2-MPC Tweco connectors. I prefer Lenco brand for price and quality.
    https://profax-lenco.com/wp-content/...Profax2021.pdf
    Page 15, are the connectors for the machine. CT-40FA (angled) CT-40FS (straight)
    Page 13, are the connectors for your cables. LC-40 Pick male and female as needed
    I shop at weldingsupply.com, because they are the best price and a local store to me. If you're stuck on Tweco brand, let me know and I will try to provide numbers. I'm just more familiar with Lenco because I buy/own a lot of it
    "Stick-man"
  31. Likes Jonath108 liked this post
  32. #21
    You can get Chicom knockoff DINSE connectors pretty cheaply on ebay, FWIW. I bought some and they seem to work fine.
  33. Likes Jonath108 liked this post
  34. #22
    Feb 2021
    NY
    Thank you, Stickman ! Lenco should be fine.
  35. #23
    Jun 2009
    Draper, UT
    I put a pair of 50' #2 leads (100' total) on my Idealarc 250 with no issues (though I don't go over 1/8" 7018)
    So from the chart above I could have gone to 150' with 60% duty cycle @200A and still use #2
    I bought Southwire Royal Excelene brand from a major wire and cable supplier via their ebay site.
    Really nice flexible stuff.
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  36. #24
    Feb 2021
    NY
    The connectors for the machine as well as for the leads call for 1/0 as a minimum wire size.
    I was told that #1 awg was fine for 300 or 310 ( max on dial arc ) for a total of 50’ leads.
    The connectors that have #1 as a minimum size only go up to 250 amps.
    I like to have the ability to max out my amps at 310 if needed, therefore I will need the connectors good for 350.
    There are no connectors I see that are good to 300 amps.
    Thanks
  37. #25
    Thanks
    I didn't know they were rated that low. I've seen and used lc-40 connectors at around 400 amps with no issues.
Page generated in 1,623,920,017.49421 seconds with 13 queries
