Results 1 to 11 of 11
Thread: Wazer water jet
    Feb 2019
    Snyder TX
    Wazer water jet
    Anyone ever heard of a Wazer Desktop Water Jet? Looks pretty cool & ONLY $8k.
    https://www.wazer.com/
    There is one in an auction I am watching - wonder what it will sell fpr?
    Aug 2018
    'ta town, KS
    Re: Wazer water jet
    Fireball Tool did a review of it, I don't remember when, or what he said just that Jason did a review
    Mac
    Re: Wazer water jet
    Looks like a pretty decent machine if you want a water jet.
    I thought about getting one so I could cut out pre-forms to forge into hinge straps or bottle openers. Never pulled the trigger, though, because even that low-level price tag is way out of my budget.
    It certainly looks like it'd be great for a small shop when you compare it to similarly sized laser and plasma cutting tables.
    Dec 2008
    Colorado
    Re: Wazer water jet
    Will it cut Hardox 450?
    jrw159
    Sep 2005
    Cave Creek AZ
    Re: Wazer water jet
    Quote Originally Posted by jrw159 View Post
    jrw159
    Just about any process will cut it, just a matter of how long it takes.
    Feb 2019
    Snyder TX
    Re: Wazer water jet
    That one sold for $2000. Would have been a great deal - If I had $2k!
    Re: Wazer water jet
    Quote Originally Posted by cwby View Post
    No kidding. If I knew you personally I would have loaned you the money! (Or maybe not! )
    Apr 2016
    CA
    Re: Wazer water jet
    Water jet looks pretty neat. Do they have a max cut depth like plasma? Also do they have a cleaner cut line that is not angled like plasma?
    Dec 2008
    Colorado
    Re: Wazer water jet
    I know. Just went through a bit of it and tried to mill it. LOL
    We took it to a water jet company. Took awhile. Just wondered if this one had the capacity to handle it.
    jrw159
    Oct 2009
    Cartersville, Georgia
    Re: Wazer water jet
    jrw159
    Definitely cheaper to sub it out. The wazer machine uses glorified pressure washer components, so it cuts incredibly slow, and uses an insane amount of garnet to make up for the lack of pressure. There's a reason the 'starter kit' comes with a literal pallet of garnet.
    Take a look at the cut time and garnet use on their sample part for various metals. I don't see the dimensions listed, but I think I remember reading that the part is less than 3 x 4".
    https://www.wazer.com/materials#.category-metal
    Who is John Galt?
  11. Likes 12345678910, farmall liked this post
  12. #11
    Aug 2018
    'ta town, KS
    Re: Wazer water jet
    We have 2 water jets and a plasma table in our department at work, yeah we get some cool toys. Max cut? I have seen the flowmax cut 6" 4130 and it was OK, but it runs at 27k psi. The Omax took on the same job about a week later, ran underwater, and under half the time. Pristine waterjet kerf marks... differenct 30 years of technology and 23K psi as in it runs at 50K psi. They are a cleaner cut line by far, but higher cost of consumables for what we do at work. I haven't seen too much AL cut on a plasma that didn't take the same amount of time to grind off the slag that was left on it. Our welders take the waterjetted parts knock the scale off them and weld, or buff for AL.
    As a machinist they both suck for true square cuts, but higher pressure on the waterjet is better than plasma. You get deflection with both processes, but it all depends on thickness of material, material type, and psi of the waterjet for your finish. Our Omax is 5 axis, and can have very little deflection on 1/2" but 1 inch... forget it, there will be deflection.
    Mac
  13. Likes N2 Welding, farmall liked this post
Page generated in 1,623,832,420.19690 seconds with 12 queries
