Page 1 of 5 123 ... LastLast
Results 1 to 25 of 121
Thread: ArcFlat Welding Table
    Apr 2020
    AntHome 92025
    I bought one. Liked it so much, I bought another. https://www.langmuirsystems.com/arcflat
    Sure beats my self-made uneven table. The clamps and etc from Strong Hand tools make assembly so much quicker.
    Together the tables weigh about 320 pounds. Added casters and can roll it around with one hand. Very happy with this.
    Langmuir is local to me - saved $200 on shipping.
    Was in a hurry to set the first table up and use it, so I bought the leg set. I needed to shorten the legs and add casters to match the table height of other benches/tables in the garage. The legs are 3" square tube. When I cut them down, the wall thickness was was only 7 mm and the inside of 3 of the legs were rusted. They do seem to support the weight, however I would make them myself if I was to do it again.
    With the first table I bought, the holes were too small on the top. Not wanting to exchange it, I drilled them out to 5/8". Probably not the most elegant solution as opposed to reaming them (no reamer), but the clamps and etc seem to work fine as they operate on a bind system. The holes on the sides of the table are sloppy at around .041" in diameter plus or minus. The second tables holes in the top are fine. The holes in the sides are the same as the first table. Am not sure if the holes in the sides will present a problem. So far, haven't needed to use them.
    I purchased their special bolt kit to join the tables together. I carefully followed their instructions and double checked the setup before injecting the fast set epoxy and clamping the bolts down. Where the tables join, they aren't totally horizontal about the last 9" of the seam. Shee... It's very slight - maybe 1/32" at most and not really a problem to me so far (I put that part of the table to the back). A chunk of aluminum bar stock 1 x 2 x30" set across the tables show the joined tops as flat. Am not sure if I messed up in assembly, but think it's a machining issue. One table edge "slopes" off starting about 3" from it - about the width of the machining bit.
    Millermatic 255
    Everlast Typhoon 330
    Ready Welder I
    Hypertherm 30XP
    Apr 2020
    AntHome 92025
    Re: ArcFlat Welding Table
    I need to correct a few items in the original post since I can no longer edit it: The wall thickness of the square tubes was .070" not 7 mm. The holes in the sides (random sampling) range from .0629 to .0641" in diameter - not .041" diameter.
    Millermatic 255
    Ready Welder I
    Hypertherm 30XP
  3. Likes VaughnT liked this post
    Apr 2017
    placerville, CA
    I am thinking of buying an arcflat table. but i need to be able to roll it around in my garage. has anyone added casters to this table? if so, can you tell us how you did it? i am not sure if i should use casters with a post (threaded) or if i should weld on plates so i can bolt on the casters. any suggestions? recommendations on casters? can you provide some pics of your caster installations?
    it seems to me the table is priced reasonably and fixturing should help with my weld projects. any feedback is appreciated.
    Apr 2020
    AntHome 92025
    I used these: https://www.amazon.com/tonchean-Leve...167176&sr=8-16
    They work very well. Can easily roll the table (on cement) with one hand. Gotta keep the floor clean - they don't like welding bb's etc.
    Millermatic 255
    Ready Welder I
    Hypertherm 30XP
  6. Likes whtbaron liked this post
  7. #5
    Apr 2017
    placerville, CA
    robert-r, thanks for the feedback. i ordered a single table 24 x 36 and the legs. once i get it i will give more thought to what kind of casters i want to use on it. your choice is interesting.
  8. #6
    Aug 2019
    northeastern PA.
    did you give thought to step down casters? step on them to raise the table on wheels and lift them to set the table back on the floor.
  9. #7
    Apr 2017
    placerville, CA
    [QUOTE][/QUOTE did you give thought to step down casters? step on them to raise the table on wheels and lift them to set the table back on the floor.
    no i had not considered that. good idea. by any chance have you used these? on the arc flat table legs? do you have any pics? thanks for suggesting.
  10. #8
    Sep 2020
    I've been debating the purchase of one of these tables but in my research I haven't been able to find anything about the thickness of the tabletop. Can you provide an measurement?
    TIA
    Sent from my SM-G975U using Tapatalk
  11. #9
    Pensacola , Fla
    Robert-R I am not sure of the need for the third hand assembly when you are clamping directly on the table???
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  12. #10
    May 2021
    Landrum, SC
    Looks like a nice *** table. Kudos.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ĵ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  13. #11
    2nd ground to the welder so it doesn't arc to the table top?
    Nice table
    My line of work was to big for tables.
    If lucky it fit on horses and shim the work or horses to be leave. Other time for larger work 4x4 on ground.
    The only plus was a rake for cleaning the ground.
    Quote Originally Posted by robert-r View Post
  15. #13
    Apr 2020
    AntHome 92025
    Quote Originally Posted by projectPONY View Post
    TIA
    It's approximately 3/8" thick. It's a sand cast table and the underside is rough. Not a problem for me, but ball lock pins don't work.
    Millermatic 255
    Ready Welder I
    Hypertherm 30XP
  16. #14
    Apr 2020
    AntHome 92025
    Not sure about that. Hasn't happened so far. fwiw - I keep a smashed braid of 12v battery wire between the work clamp and the table.
    Millermatic 255
    Ready Welder I
    Hypertherm 30XP
  17. Likes whtbaron liked this post
  18. #15
    Sep 2020
    Thanks for the response. Can you elaborate on why the ball lock pins don't work? I Assuming it's the thickness, or lack there of, of the table.
  19. #16
    Apr 2020
    AntHome 92025
    They need a smooth surface on the underside of the table. Also, it's the thickness of the table.
    Millermatic 255
    Ready Welder I
    Hypertherm 30XP
  20. #17
    Sep 2020
    Gotcha
  21. #18
    Jun 2022
    Greetings everyone. It's my first post here (new member). Did anyone ever find ball locks that work on this table?
  22. #19
    Jan 2022
    Sugarland, GA
    Nice table. Would look good in my shop.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  23. Likes 52 Ford liked this post
  24. #20
    Dec 2020
    Virginia, USA
    Quote Originally Posted by opa View Post
    Here's my 2 cents : weld some 3/8" plate to the bottom of the legs. Then drill and tap some holes to bolt the casters on. Bonus points if you can add some jam nuts to the bolts.
  25. #21
    I think what 52 "meant" to say was drill and tap the plate before welding to the bottom of the legs...
  26. #22
    Dec 2020
    Virginia, USA
    Words is hard.
  27. Likes Lis2323, NotaVegetarian liked this post
  28. #23
    Jun 2022
    Does anyone have any ideas on building some legs to make the table able to tilt?
  29. Likes 52 Ford liked this post
  30. #24
    google "images" for ideas.
  31. #25
    Laredo + Midland/Odessa
    Quote Originally Posted by Pbclax1 View Post
    I'm working on an idea for that very concept for my dual Certiflat 4'x3' tables (essentially 4'x6'). I'm going with a very, very heavy base that has a small foot-print so that I'll be able to tilt the table and be able to roll it out of the way instead of permanently giving up 24 ft² of valuable floor space when I don't need to use it.
Page generated in 1,713,244,626.51721 seconds with 19 queries
