Results 1 to 5 of 5
Thread: Wanted spoolmatic 3
    Dec 2014
    sw minnesota
    Wanted spoolmatic 3
    Looking for a spoolmatic 3 for my millermatic 200 and cables to for a wc1 to connect to my other Miller matic 200 for spoolmatic 1
    May 2008
    Orange, TX
    Re: Wanted spoolmatic 3
    Prior to the MM200 serial number JJ407380, the Spoolmatic 1 is a direct connect that doesn't require the WC1 weld control. Effective with serial number JJ407380 the WC1 is required to use the Spoolmatic 1 but the Spoolmatic 3 is a direct connect.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2014
    sw minnesota
    I couldn't tell you the serial numbers of the machines of hand right now but they both have 14 pin plugs on them
    May 2008
    Orange, TX
    The 14-pin receptacles make the SM-3 a direct connect for both machines. You could also use the current - and lighter - Spoolmatic 15A or 30A guns with the WC-24 with both machines.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2014
    sw minnesota
    Yeah I have thought about getting a 30a but I can't afford it for my shop.
Page generated in 1,624,259,048.50130 seconds with 11 queries
