Results 1 to 20 of 20
Thread: Help - gate latches and hinges
    Sep 2008
    Dalton, GA
    I give up on picture orientation.
    I am going to build this gate in a breezeway. The walls are stucco over stud wall construction. One problem is the studs are not lined up from one side to the other - about 4Ē difference. I can deal with that.
    My questions right now are the hinges and latch. I cannot use a cane to make one gate fixed so the latch has to keep the 2 gates in place. Iím thinking a slide bolt that can push from either side into a long enough tube to secure or else a latch that rotates up and down 90*.
    Second question is what are best hinges that only let the gates swing one way. I think weld-on barrel hinges are probably the best. I guess I would either use stops on one side or else offset the hinges.
    Any guidance, recommendations, or links to best products are very much appreciated.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
  2. Likes geezer liked this post
  3. #2
    Mar 2004
    hueytown, ala
    Re: Help - gate latches and hinges
    here you go Burt Name:  gate.jpg
    you could sink a metal post on each end and not attach to wall, then gate can be where you want it... I think a long slide bolt or tube would be your best option fir securing both gates with some type lock at one end
    nice design BTW
    john
  4. Likes wb4rt, snoopdogg liked this post
  5. #3
    Gate latches come in a thousand varieties and it really depends on how much work you want to put in to them. A bit of hand-forged goodness goes a long way!
    This one, for example, could be redesigned so there's a handle and catch on both sides, thus trapping both sides of the gate with a very solid mechanism. Scale it to fit your uprights and it could be welded up from scraps you already have collecting dust in a corner somewhere!
    The easiest way to make hinges that only rotate one way is to weld stops right onto the barrels. Once you have everything tacked onto the gates, weld a short stub of 1/4x1/2 onto the lower barrel so it's flush with the joint between the barrels. Then weld a similar stub onto the upper barrel so it hangs down a bit and will run into the stub on the lower barrel when the gate's at the position you want. Make sense?
  6. Likes wb4rt liked this post
  7. #4
    Sep 2005
    Cave Creek AZ
    To make latching easier make the gates self closing. Then just use weld on barrel hinges. I use 1/4” spacers in between the tubes when welding on the hinges. When you weld the hinge onto the outside of the joint, weld a spacer on the opposite side (but just to one piece of the tube. This will allow the gate to close only to a certain point and then stop. Then you add springs or closers and they will want to stay that way.
  8. #5
    this is not an area that I have a lot of expertise in.
    I do gates that shift with the soil conditions. Agricultural gates. Not tied to a solid building, although buildings do shift.
    If I were to redesign any of those gates, I'd try to have some means to adjust the hinges.
    The only problem is...........if you have an adjustable hinge, it generally isn't as rigid as a plain ol' hinge. I'm thinking you'd give up a lot with an adjustable hinge, unless it was secured to the building with wedges under the fasteners.
  9. #6
    May 2007
    SoCal
    HD adjustable hinges I was advised of by one of my welding teachers who owned a fence building business.
    Search:- KCHEX (2X) Heavy Duty Gate Hinges - 3/4" J-Bolt Adjustable 900lb Capacity Ball Bearing
    Actually, they are shown upside down.
    There is a greasable ball bearing inside, really smooth! You can make your own stop mechanism, I suppose.
    I used two different sizes here (as sets of two), one in the driveway, and one on the side yard. Both are buttery smooth.
    Job 28:1,2
    Danny
  10. #7
    Sep 2005
    Cave Creek AZ
    If you put in adjustable hinges I can guarantee you will be back to adjust them. Measure accurately, build stout, use good install methods, and be done with it.
  11. #8
    Sep 2008
    Dalton, GA
    Looking at Vaughn’s latch in post #3, I think I will build a similar latch that swings up and down so it extends far enough to secure the double gates together.
    I need a couple of small rosettes, buttons, or medallions for the latch. I thought I would weld a 1/2” round spacer behind the rosette for the latch to go over. Any body have a source for these? I have searched online but not found what I’m looking for.
    I saw some wrought iron cabinet knobs similar to what I need but not sure they would be sturdy enough. See link.
    https://www.houseofantiquehardware.c...-inch-diameter
    Any ideas are appreciated.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  12. #9
    Looking at Vaughnís latch in post #3, I think I will build a similar latch that swings up and down so it extends far enough to secure the double gates together.
    I need a couple of small rosettes, buttons, or medallions for the latch. I thought I would weld a 1/2Ē round spacer behind the rosette for the latch to go over. Any body have a source for these? I have searched online but not found what Iím looking for.
    I saw some wrought iron cabinet knobs similar to what I need but not sure they would be sturdy enough. Any ideas are appreciated.
    You can make your own if you have a torch to heat the steel with. Making rosettes and buttons is very easy work, especially if you start with something like a bolt or large nail that already has the shank upset and thickened.
    Here, you can see that a round-nose punch was simply driven into the corners of the large square-head bolt, and the washer is made from some 2x2x1/4" flat bar. The bolt head was left as close to OEM specs as possible so wrenches would still work on it, but it didn't have to be. Use several different punches and chisels, and you end up with something that looks very unusual and "custom".
    Here's a larger rosette I had cut out for me as blanks that I could then chisele and forg to give depth and texture. Stacking them just make them even more "organic"
    Kim Thomas did a pretty decent video of how he makes a decorative lag screws. I've been meaning to test it with some #10 wood screws to see if the welding would make the screws impossible to drive into wood, but haven't gotten around to it yet. The basic technique, though, can be done with anyone who has an O/A rig and other basic tools, and adapts to welding the head onto the crossbar that'll join to the other side of the gate. If you can make the gate, making the latch won't be a stretch for you!
    Personally, I wouldn't press the heads into the black because it'd be easier for me to just cut the heads off and then weld them in with some 7018.
    Want a round head, start with round bar and drill out the center on the lathe.
    Feel free to shoot me a PM if you have any questions.
  13. Likes wb4rt liked this post
  14. #10
    This video shows a neat idea for a center-pass latch, and lots of variation on the idea. Maybe not perfect for your design, but something to maybe build from......
  15. Likes wb4rt liked this post
  16. #11
    I cannot see why it would be a good idea to put a stop on a hinge. Or a slide latch between two gate where one is not dogged. ??? Seem like bad designs unless purely decorative.
  17. #12
    Mar 2007
    MidWest
    Burt, You may have struggled some with picture orientation, but your gate design looks great. Hope all works out.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  18. #13
    I build my hinges from scratch
    Most it faster and fits the gate.
    On large gates I Pillow block bearing.
    Gates and top hung doors use tubing. For four point support doors I use pressform or channel this so can flex with building.
    Quote Originally Posted by geezer View Post
  19. #14
    Sep 2008
    Dalton, GA
    Well, after a lot of work and considerable head-scratching here is where I am on the gates. I used barrel hinges and built a homemade latch from VaughnTís inspiration.
    I built bolt-on posts out of 3/4Ēx2Ē cold roll. They turned out pretty nice. Iíll post a picture of them after installation.
    Still some grinding and clean up before taking to my powder coater on Monday.
    Closeup of latch.
    Sorry for the messy background but these guys are too heavy to move for a photo shoot.
    Now, looking for thoughts on the mounting. The steel posts will rest on concrete and be lag bolted to the stud walls. I opened one side wall and put in a double stud firmly attached between 2 studs to line up with opposite wall. The opposite post will be lag bolted to a single stud. I cannot reinforce that stud.
    The gates each weigh around 65 pounds. Iím a little concerned about the single stud. Since the actual weight is carried to the concrete by the post, it seems to me I should be okay.
    Iím thinking of using construction adhesive behind the posts to the wall to minimize any play from the gates swinging.
    Any encouragement or suggestions appreciated.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  20. Likes ccogg, albrightree, VaughnT liked this post
  21. #15
    Looks good.
  22. #16
    Not sure if you are finished welding. However, those tight joint around your rings will be difficult to coat well. Welding and wrapping the top and bottom of the joint will be worth it. Also, solid weld the collar top and bottom.
    If those are cast iron collars, then there is great potential for them to fall down. Unless there is a stop weld underneath. Strike a couple with a hammer to test.
    Will you be able to bolt to the concrete? It would resist some twisting that may occurs and provide some additional support to the single stud side.
  23. #17
    Sep 2008
    Dalton, GA
    Thanks for the reply Tapwelder.
    All good recommendations. I think a plate anchored to concrete floor will greatly help minimize twisting.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  24. #18
    You may this type hook lock
    You buy housing that can be welded in doors and gates.
    https://www.amazon.com/Storefront-Mo...16213779&psc=1
  25. #19
    Sep 2008
    Dalton, GA
    Update ó-
    Installed the gates today. I was surprised and pleased how well they look and work. They meet with a consistent gap between them.
    The posts are very secure and Iím confident will hold the gates just fine. I took Tapwelderís advice and added base plates to the posts. That was great advice.
    Here is the latch I made. Customer really likes it.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  26. Likes Larry4406 liked this post
  27. #20
    Looks nice. Since you have so much railing there, a good eye test is see if the pickets dance or make you dizzy as you look through all the railing and gate. I they do then something is not plumb. Yours do not dance.
    You did well. The whole job looks good.
    Sometime I will walk around a railing with one eye closed, seeing visually hide one picket behind another.
  28. Likes wb4rt liked this post
Page generated in 1,623,612,459.12623 seconds with 13 queries
