Results 1 to 9 of 9
Thread: What would be the amount of deflection or breaking strength of 1/4 2x2 square tubing
    center NJ
    Iím Reinforcing the front of my trailer so I can put a winch on the top headache rack board and winch stuff into the back.
    If you had a L shape welded 2x2 1/4 square steel tubing that the bottom leg was 22 inches and top leg 32 Inches .
    With the load Applied to the top of the 32 inch tubing in the direction of the shorter leg side what would be the amount of deflection pre pounds of weight?
    It would be full pen mig welded
    Mar 2021
    Near Roanoke, VA
    Re: What would be the amount of deflection or breaking strength of 1/4 2x2 square tub
    With a 32" lever arm, something would likely buckle,, to failure , ruining all of your strength calculations,,
    Aug 2016
    So something like this:
    If so, the moment (flexural) capacity of a 2" x 2" x 1/4", grade 50 ksi, square section is approx. 28.9 k.in (28,900 lbf.in)
    For a 32" lever to applied load, P, that equates to 900 lbf, applied horizontally (28,900 lbf.in/32" = 900 lbf)
    If 900 lbf was applied horizontally in the structural model/simplification above, the horizontal displacement/deflection would be approx. 0.77".
    BUT, you need to resist the base moment around the corner of the vert/horiz connection. I suggest gusset plates.
    You also need to make sure the horizontal section is sufficiently connected to the base.
    And you also need to make sure it is braced for the out-of-plane direction, too.
    LINCOLN
    Square Wave TIG 200
    Power MIG 210 MP
    Ranger 330 MPX
    MILLER
    Thunderbolt AC/DC
    HYPERTHERM
    Powermax 190C
    Powermax 45XP
    HOUGAN
    HMD 130
    HMD 505
    FEIN/SLUGGER
    14" COLD METAL CHOP SAW
    9" COLD METAL HAND-HELD SAW
    center NJ
    Thank you very much thatís a lot weaker then I was Expecting.
    Iím gonna post some pics when I get home tonight so you guys can see the overall picture what Iím doing.
    I Planned for a gusset plate but the inside corner is butting up to a 2 x 6 steel frame so the gusset will be a thicker L
    Have you considered putting a pulley/roller/sheave in the bottom corner so the cable/strap is close to the floor and the pull from the winch is straight down on the post and the lateral pull is near the corner?
    ---Meltedmetal
    center NJ
    I want to keep it higher to pulls things up the ramps the trailer sits high.
    The painted part will mount to the front inside The unpainted still needs to be finish it will mount to the front outside though bolted and welded on the bottom frame.
    Itís a dump trailer and itís half raised
    The eye bolts are made to have a chain run though them and hook to the two middle chain hooks for heavy things . Name:  1626471F-FE68-459D-AFA9-A6F30C5D9D61.jpg
Size:  135.3 KBName:  99E28F10-3003-40A5-A972-DE88A422EE5D.jpg
Size:  207.2 KBName:  5126A03C-14D4-4A2A-88FA-14EDE082A09A.jpg
Size:  155.1 KBName:  5C464359-1AF0-4196-9BC6-D578D3374F00.jpg
    Sep 2014
    Quote Originally Posted by Bigrich954rr View Post
    Guys rip out the floor-mounted winches, box, and all from the bed, with the wench below the bed. I usually make a thicker box and then it gets welded in.
    Sincerely,
    William McCormick
    center NJ
    Sincerely,
    William McCormick
    So whatís your thoughts on my setup ?
    I did weld a 3/8 2 inch steel Reinforcement on the bottom of my L to span the weld and connect all sides of the box to the lower L part
    The winch will mount on middle top and center. On the middle chain hook
    Sep 2014
    It will only be as strong as that piece with the hooks, can support it straight up and down. As soon as the winch is loaded, the force because of the gusset behind will transfer the force to the horizontal piece with the hooks and all the force will be almost straight down on that horizontal piece. It will put a lot of stress on that gusset weld.
    It would almost be the same as mounting your winch in the front of the trailer and putting a pulley to let the cable ride through on that center support with the hooks. That would be better as it would remove some of the horizontal movement, from the front to the back of the truck as the winch is loaded with pressure. The pressure would be down on the support with the hooks. It may work for some time but with a cable creating the stress I would not want to stand near it loaded, because that center support will flex and create spring tension.
    Sincerely,
    William McCormick
Page generated in 1,621,069,251.70082 seconds with 12 queries
