Results 1 to 17 of 17
Thread: Mig gun won't arc
    Apr 2021
    Mig gun won't arc
    On my 3rd welder from HF and can't figure out what keeps going wrong. Started with the titanium 170. Ran a little flux core just to try it out. Got about an inch of weld down stopped for a second, went to weld again and it won't arc. Took it back upgraded to the unlimited 200. Welds less than half an inch and stopped arcing. Would stick weld but the tig gun won't arc. Changed it out for the omnipro 220, ran a new 240v outlet (the other 2 were all on 120v) got everything hooked up and the mig gun never arced once. Again I can stick and tig weld with no problems. Am I doing something wrong or are these welders that bad?
    Sep 2016
    Detroit, Michigan
    Re: Mig gun won't arc
    Quote Originally Posted by Jdevon View Post
    I don't think anybody has any chance of answering that without a lot more information. Setup, shielding gas, process, material....all those variables and more can change how things should work.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Check manual for setup instructions. Are all connections tight ?? Is material clean ? Does wire feed when trigger pressed ?
    Does Harbor Freight have tech support ??
    Apr 2021
    It's flux core no shielding gas welding on new clean 18 gauge steel. Doesn't matter what settings are used on all 3 welders it won't arc
    Apr 2021
    Yeah all connections are tight the material is brand new clean steel. All 3 would feed wire. I've called there tech support but they didn't know what a mig gun was so they were no help. Not getting any errors from the welder. At first I thought my outlet was messing something up so I ran a new 240v plug and same issues
    Dec 2008
    Did you use the same mig gun on all three welders?
    Or ground cable for that matter?
    Apr 2021
    Quote Originally Posted by rexcormack View Post
    No all 3 I used the new gun and ground clamp that came with the welder.
    Dec 2008
    I don't own a mig so I cannot help any more.
    My one suggestion would be to post photos of the front of the machine and inside the side door.
    Did you try removing the flux and see if bare wire arcs ?
    Does machine have drive rolls for flux core ?
    Apr 2021
    Yes I've tried solid wire and it has the same problem. And yes it has different drivers for flux the wires feeds fine just not arcing
    Dam, time to go buy a Miller.
    Dec 2003
    Fairfield,CT
    Is there a spot timer on these. Sounds like you have it on if it has one. I had a HF TIG 205. DOA out of the box. Got my money back never again.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Sep 2016
    Detroit, Michigan
    You said the "tig gun won't arc" at one point, and mentioned trying solid wire as well, which is why I asked. You need shielding gas to get a TIG arc started.
    http://mivise.com
    Apr 2021
    My issue was user error. Once I placed the torch tip 1/16" away from the material, then pressed the pedal it worked correctly. The machine has an auto stop feature so that if the gap gets too wide or I ground out then I have to let off the pedal before restarting. I had never Tig welded before. I also got a bottle of 100% argon and I don't see any difference between 100% and the 75/25 mix I use for Mig welding. So that is the resolution for my issue.
    Sent from my SM-G950U using Tapatalk
    Apr 2021
    Yep my bad was supposed to be mig gun. The tig and stick work just fine.
    Mar 2015
    usa
    i would try returning for a refund plus extra for all the greif. then buy something good like miller.
    hypertherm powermax 30xp
    fronius transpocket 180
    fronius transsteel 2200
    fronius iwave 230i water cooled
    hobart handler 100
Page generated in 1,713,271,613.42288 seconds with 18 queries
