Results 1 to 5 of 5
Thread: Trouble with Blackface Sa200
    Apr 2021
    I have been welding with this machine for a few weeks with no problems. Then all of a sudden it quit welding. It ran a grinder but won’t strike an arc. It would idle up and still wouldn’t strike an arc. Now it won’t idle up when I go to strike an arc. I can manually idle it up and it will weld, just wondering if anyone had any ideas? Your help is appreciated!!
    Apr 2021
    Re: Trouble with Blackface Sa200
    What’s funny is I have proper amperage at the positive/negative lugs. My ground? Bad connection at stinger? Any ideas?
    Apr 2021
    Just checked the positive/negative lugs again, now it’s showing an open circuit. My welder is going berserk.
    May 2008
    Orange, TX
    Could be failed main shunt coils or bad contacts on the coarse amperage selector switch or a broke copper strap to the coarse amperage selector switch or . . .
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Aug 2021
    My SAE-600 did this exact same thing the other day. As it turns out the fine adjustment rheostat had burned up. I think it's labeled "Job selector" or something like that, but it controls the output voltage of the machine
Page generated in 1,713,271,662.50744 seconds with 18 queries
