Results 1 to 6 of 6
Thread: Hypertherm 45xp
    Oct 2020
    Hypertherm 45xp
    Not sure what Iím doing wrong. Trying to gouge out some welds with a new 45xp. Old cutter was a straight 45. Problem is arc will start but wonít stretch out to get deep enough in 90degree corner. Thanks
    Apr 2021
    Re: Hypertherm 45xp
    Not sure exactly what you mean. Does the 45xp have a gouging mode? I use a PM85 so I'm not overly familiar with that model.
    Sent from my moto e6 using Tapatalk
    Oct 2020
    Re: Hypertherm 45xp
    Once the arc strikes and I start to cut when the tip gets 3/8-1/2Ē off the material the arc cuts out and I have to start over. Iím using gouging mode with the consumables that came with it but they are not the same as the original hypertherm 45 (not inner changeable with 45xp) donít know if I need different consumable tips or what??
    Dec 2011
    Tampa FL
    Re: Hypertherm 45xp
    There are specific consumables for gouging with the 45XP, are you using these or the standard consumables?
    Mike
    Apr 2021
    Re: Hypertherm 45xp
    Sorry, I assumed you had gouging consumables. The Gouging shield and nozzle is completely different from the cutting parts.
    Oct 2020
    Re: Hypertherm 45xp
    Yes I am using the gouging consumables. After a little more research what I have is the Max control shield. I think I may need the Max removal shield instead. Thanks guys
Page generated in 1,624,029,952.83206 seconds with 11 queries
