Results 1 to 14 of 14
Thread: Will a respirator fit under a pipeliner helmet?
    Jun 2011
    Texas
    Sometimes I wear a respirator when I'm welding, depending on the filler and/or materials. Lately I've been contemplating getting a pipeliner type helmet (let's not get into the whys). Will a respirator fit under a pipeliner? It BARELY fits under my Miller Digital Advantage, which is quite roomy, and it looks like a pipeliner fits much more snugly. I don't want to get one if I can't wear a respirator under it.
    -Ruark
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Apr 2021
    Re: Will a respirator fit under a pipeliner helmet?
    I use miller p101(I think) under my hoods. Works good and the for is nice. It does touch the led display of my digital infinity but it's ok.
    Sent from my moto e6 using Tapatalk
    Laredo, Tx
    As long as the headgear is adjustable so you can vary the front-to-back distance from the front of the hood to your face, then yes you can make it work. I have a cheapie plastic hobart one I use for oxy-acet and my 3M respirator 6503QL fits just fine with the proper headgear adjustment.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jun 2020
    I agree, I think the key role played by the possibility or inability to adjust the helmet!
    May 2007
    i got that 3m , ill try to remeber to check. anyway, u might have to wait until they do a pipeliner production run again
    Jun 2020
    Yes, it's a great option - it's convenient that it has four-point Head Strap Adjustments.
    NW New Jersey
    Cool Re: Will a respirator fit under a pipeliner helmet?
    I think its the next series up maybe the 7500 3M takes the same filters but the exhaust valve is ported down. Makes for less fogging. I think it fits the same under the hood clearance wise. I should check next time I'm in the shop. I also use a disposable 3M welding
    respirator when I'm not in the shop. It has a valve on the front. 3M 8212/8214 perhaps ?
    -Features 3M™ Cool Flow™ Valve, Adjustable Buckle Straps, Advanced Electret Media, Cake-Resistant Filter Media, Faceseal, Welding Web
    -Filter Class N95
    -Flame Resistance (ASTM D2859-96) Yes
    regards
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    P100 is a better filter than an N95.
    Jan 2011
    W. Wisc
    Generally...what is more important than the filter efficiency (N95 vs P100) is how much you wear it. If you skip wearing it for "quick jobs" or immediately take it off after you are done grinding but still standing in the same spot when you were grinding, then you are exposing yourself 100% for that time. If you wear it religiously, then it might help you a little to use a higher efficiency respirator filter, but few people are that meticulous. It is more important that you WEAR IT and don't take it off than it is exactly what the efficiency is. Of course if you are operating under OSHA or some other regulation that requires P100 or something, you need to meet that no matter what, but this is a point to try and explain what is most important in reality.
    -Dave
    Most welding respirators are P100. Proper fit is the most important. Some places don't allow any facial hair but that's usually for full face respirators.
  12. Likes farmall liked this post
  13. #12
    Jun 2020
    The P100 filters 99.9% of airborne particles, including oil-based particles.
  14. #13
    Jan 2011
    W. Wisc
    Quote Originally Posted by kennystone View Post
    99.97% actually, but who's counting?
    -Dave
  15. #14
    Jun 2020
    Yes, that changes everything dramatically
Page generated in 1,628,154,649.32147 seconds with 13 queries
