Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Inexpensive bevel tool
    Fredericksburg, VA
    Re: Inexpensive bevel tool
    pat, does this tool bevel edges that have been plasma cut of course after the dross has been removed. Not sure if you example is of plasma cut plates. Thanks.
    T.J.
    Yes. Those were plasma cut pieces. I did remove the dross first as well. It handled it pretty well. I did not go for a large chamfer or depth of cut on one pass considering how small the tool is.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Jan 2005
    I machined edge will come out much nicer then a plasma cut one. The bevel is only as smooth as the materiel it rides against. Takes a plasma cut hole, and one made with a annular cutter . The different results in bevel edge quality is like night, and day..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
Page generated in 1,631,951,011.52284 seconds with 11 queries
