Results 1 to 5 of 5
Thread: Millermatic 200 Gas Valve
    Jul 2012
    I have a 1991 vintage Millermatic 200. Serial number is KB01648. I think the gas valve is bad. A couple of weeks ago, there was no gas flow for the first couple pulls of the trigger, but then it started to work. When I tried to weld yesterday, there is no gas flow at all. The manual says the part number is 116-996. Unfortunately, I can't find a reference to this part anywhere on the net, even on Miller's site. Is there some other part I can use?
    I bought the machine new in 1991, and it's never had a problem until now. Mint condition, and I hate to give up on it.
    Thanks,
    John
    Jul 2012
    Re: Millermatic 200 Gas Valve
    Have one a little older MM200 1986 the gas valve
    # 003 538 (about $80.00) and is still a good number on miller4less. It is 115vac, 2way 1/4 ips same as # 116 996.
    You can also source one from eBay from the above spec's.
    Jul 2012
    Follow up embarrassing information...
    As I was starting to troubleshooting the problem, I noticed I had the blue hose connected to the gas bottle. I immediately realized it's a case of felony stupid on my part. There is an HTP Powermig 200 sitting above the Millermatic 200, on a custom frame attached to the running gear of the Miller. I had the HTP connected to the bottle, not the Miller. The Miller has a black hose. It's amazing how once you connect up the gas bottle to the welder, it flows when you pull the trigger...
  4. Likes Broccoli1 liked this post
    city of Four Flags
    I see you got your issue fixed.
    Current part number is 218421.
  6. #5
    Aug 2019
    northeastern PA.
    Quote Originally Posted by jrwdlw View Post
    Not laughing at you, but I am laughing at you. I have several machines close to each other. I grabbed the plug and stuffed into the outlet and the darn machine wouldn't turn on. I started cussing the "stupid machine" taking a dump. The A G E thing is definitely kicking in.
Page generated in 1,623,920,932.75837 seconds with 12 queries
