Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: Antenna Base
    Mar 2014
    Troy MI
    Re: Antenna Base
    Does that mean the antenna is two meters high? I guess it's a full wave antenna??? I don't know much about this kind of stuff.
    Yes, the example that you linked to is a full wave vertical 2 m antenna. They also make them in an array that can have elements that are full wave, half wave or quarter wave. The array helps boost the signal. Below is a picture of a 2 m array antenna. Ray will use some type of an array antenna like the one shown below. Iím not sure if it will be 1/4, 1/2 or full wave. The elements can be vertical as shown or horizontal.
    -Don
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
    Mar 2014
    Troy MI
    Re: Antenna Base
    Here is another vertical array.
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    CT
    Re: Antenna Base
    Not necessarily. It could be anything from a 1/4 wave ground plane (about 19-20 inches in overall length) to a co-linear antenna like the one you linked to (two antennas in phase to achieve gain and a lower take off angle). 2 meters refers to wavelength of the band/frequency range, but its a generalization because the 2 meter band actually extends from 144 mhz to 148 mhz.
    CT
    Re: Antenna Base
    Could very well be
  5. #30
    Re: Antenna Base
    Looks like a great job.
    Like milling most time on site I see welding.
    Quote Originally Posted by Don52 View Post
    My friend and customer Ray designed a base for a Ham radio antenna that will eventually be mounted on top of a school, which is the highest point in the area. I machined all of the components for the antenna base. The antenna will be used for a Ham radio repeater station. The school didnít want him to drill holes through the membrane of the roof, so it has to rely on weight and a large base to keep it from tipping over in the wind. The first step was to face and cut the stock to length.
    1. Cutting Off Stock 1
    Attachment 1727361
    2. Cutting Off Stock 2
    Attachment 1727362
    The next step was to set it up on the Bridgeport to cut the slot. I removed the chuck from the lathe and clamped it to the Bridgeport. Then I used a center finder to find the center of the stock so that I could zero my digital read out.
    3. Finding Center
    Attachment 1727363
    Next, I drilled the center hole undersize just to remove some stock. In hind sight I should have done this step while the base was still in the lathe. (It is easier to drill a hole with the 7-1/2 HP lathe as opposed to the 1 HP Bridgeport.
    4. Pilot Drilling Stock
    Attachment 1727364
    5. Drilling Stock
    Attachment 1727365
  6. #31
    CT
    Re: Antenna Base
    I thought you said this was for a repeater installation? directional antennas like the ones you showed are typically not used for repeaters since they generally only radiate in one direction.
  7. #32
    Apr 2014
    MN/WI
    Re: Antenna Base
    ......troubles with editing...
    https://www.amazon.com/Radiowavz-Ant.../dp/B01M4NV336
    Lincoln Idealarc TIG-300
  8. #33
    Outside of Raleigh, NC
    Re: Antenna Base
    Great post Don! I enjoyed reading it and admiring your craftsmanship.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  9. #34
    Mar 2014
    Troy MI
    Re: Antenna Base
    I asked Ray to clarify your point. You are correct. This antenna is an array type, which is directional. This array antenna connects to a computer and points to another omni directional antenna that is located on top of a chair lift tower on Ski Brule ski resort that is five miles away from the school. The Ski Brule antenna is the actual repeater. Thanks for your clarification.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  10. #35
    Mar 2007
    MidWest
    Re: Antenna Base
    Thats some mighty fine machine work, well done.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
Page generated in 1,624,069,630.17730 seconds with 12 queries
