Results 1 to 10 of 10
Thread: Dozens of Holes in 2x2 Steel
    May 2021
    Question Dozens of Holes in 2x2 Steel
    I am going to build myself an excercise squat rack.
    It will be done with 2x2 square tubing (I believe 10 gauge).
    I need to drill many holes on each side of the tubing.
    What drill bit and/or hole saw would be best for this?
    Should I get something "fancy" like TiAlN ?
    Thank you!
    Aug 2019
    northeastern PA.
    Re: Dozens of Holes in 2x2 Steel
    don't know how much weight your messing with ... I would imagine 10 ga would get kind of hinky after making dozens of holes. I might be thinking out of turn, sorry. Have you given thought to a machine shop making the holes for you ... they would be indexed from side to side.
    Jun 2009
    Draper, UT
    The search function is your friend.
    This link below is the exact same application. I'd recommend annular cutters.
    https://weldingweb.com/vbb/threads/7...ght=squat+rack
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  4. Likes farmall liked this post
    May 2021
    Thank you both!
    Here's a thread in another forum showing the general idea of what I'd like to do.
    Yet in that thread there are dozens of machines ("squat racks").
    I want to build only one for my self.
    I'll see about having a machine shop drill them!
    Link to another forum --> https://forum.bodybuilding.com/showt...hp?t=157441123
    Dec 2003
    Fairfield,CT
    Not that I want to go to yet another forum, but this is pretty easy with a milling machine and annular cutters. Might want to get thicker wall than 10ga as suggested.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  7. Likes farmall liked this post
  8. #6
    You didn't mention hole size.
    I would check with steel shops in your area to see what they have and price.
    Maybe have something like this
    https://inchofmetal.com/products/ste...20002346893382
  9. Likes 12V71 liked this post
  10. #7
    My steel dealer has a punch with very sophisticated indexing precision. I ordered a piece of 3/4" steel with three holes punched to exacting measurements & sizes. It'll need honing to exactly fit the application.
  11. #8
    That's good stuff, they also make tube that will telescope over the 2" with a good fit. Obviously the main use is sign posts, but I have used the stuff for adjustable supports for pipe and many other things. Its probably plenty strong for the OP's use. If you weld on it, sand the galvy first and touch up with cold galvanizing paint.
    It's probably cheaper and less chance of insanity than trying to drill a bazillion holes accurately.
  12. Likes BD1 liked this post
  13. #9
    Just use HS drills.
    It works great and low in cost.
    I sharpen all drill bit and try some new types but last just as long as HS drills
    Quote Originally Posted by aj. View Post
    Thank you!
  14. #10
    Dec 2003
    Fairfield,CT
    This vid might give u an idea. I did this for my gate.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
Page generated in 1,624,190,139.61859 seconds with 14 queries
