Results 1 to 14 of 14
Thread: TIG welding cast iron
    Apr 2021
    I'd like to attempt a small TIG welding project - welding cast iron to steel.
    What TIG settings would you recommend?
    What type of filler rod is best?
    thanks a bunch
    Re: TIG welding cast iron
    I would per heat parts before welding around 500° to 800°F.
    I use a torch for my cast iron work as do not have tig anymore.
    Quote Originally Posted by lpm View Post
    thanks a bunch
    SoCal-LA
    I use EZ Weld Tig wire which has never failed me yet, especially on some irreplaceable expensive parts. Follow the instructions and keep the part cool.
    https://ezweldtigwire.com/
  4. Likes Woznme liked this post
    Dec 2016
    I hear aluminum bronze works good.
  6. #5
    Nov 2012
    North Port Florida
    Do you mean Silcone bronze?
    Quote Originally Posted by ljmelius View Post
    It seemed like a good idea at the time!
  7. #6
    Quote Originally Posted by welding1 View Post
    Do you mean silicon bronze?
    Silicone is a synthetic elastomer. Silicon is an element.
    But more pertinently, why is silicon bronze better than aluminum bronze for cast iron?
  8. #7
    Most old cast iron is only Tensile strength: 25,000 psi.
    Brass brazing rod is Tensile strength: 65,000 PSI
    Brassing rod lower cost than silicon brazing rod
    Quote Originally Posted by jwmelvin View Post
  9. #8
    Dec 2016
    Nope
    Jody does a good job explaining why he chose al bronze over silicon bronze.
  10. #9
    May 2021
    USA
    If you also want to know the procedure. I am sharing a link about welding cast iron here. Hopefully it would be helpful.
  11. #10
    Sep 2016
    Detroit, Michigan
    Lots of questions....is it mild steel? How thick are the pieces you want to join, what sort of joint configuration and how critical are these welds (any load on them)?
    I have had zero success with the EZ Weld stuff for some reason, but I know others have had good luck. Brazing with either silicon bronze or aluminum bronze is a good option as suggested. I've had very good luck using Inconel filler rod to join cast iron and ductile iron to mild steel....but the rod isn't cheap. It's mostly nickel, so it's similar to using a nickel stick welding rod for cast iron. I actually keep an eye on eBay for old Inconel filler rod that's new old stock or just old. Often Inconel is being used on jobs with a defined process and they require documentation on the various components, so nobody is going to use an old batch of rods....and it winds up selling pretty cheap. The last tube I got was 8lbs and I paid $30 for it...not too painful.
    One thing I've found that works really well is to use a carbide bit in a die grinder to get the cast piece down to clean, white metal...you don't want to use a grinding wheel or flap disc as they leave behind residue (at least sometimes). I get the pieces set up and then run just an arc at low amperage (no filler) along the area to be welded. You'll get black soot coming out of the cast iron...that's carbon. Stop, use a stainless brush to clean off the carbon and repeat a few times until the black soot stops, then put down your first pass with filler rod. Cooking the carbon out seems to make a big difference and it also adds some preheat to the work as well.
    If it's a small piece that you didn't put a lot of heat into you may not even have to worry about trying to cool it slowly. If it's bigger, and/or got hotter I'll throw a welding blanket over the work to help keep heat in it longer.
    If there is any way you can do a practice weld with similar pieces that's always a good idea since older cast iron can really be mystery metal and there's no way of knowing exactly what you're dealing with.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  12. #11
    You can weld with cast iron rod.
    When had a TIG weld I would weld with cast iron rod you still need to per heat
  13. #12
    Jun 2017
    AJO, ARIZONA
    Quote Originally Posted by Sophie View Post
    More spam! She's Sophie on Welding Web and Emalia John on the link she posted about cast iron, says she's from Texas but her language skills scream India , or some other scam place.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    RONALD REAGAN
  14. #13
    Outside of Raleigh, NC
    Emilia, that’s a good overall summary article about the options.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  15. #14
    I did not get that impression from reading the article, but you may be right.
    Miller Suitcase MIG
    Lincoln 210MP
Page generated in 1,623,731,259.38615 seconds with 12 queries
