Results 1 to 25 of 34
Thread: Tig Cooler water temerature?
    Mar 2005
    Under a Rock
    Does anyone know off hand the average water temperature coming IN/OUT of the torch
    a lot of variables, I realize.... But On AVERAGE.
    thanks.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Mar 2005
    Under a Rock
    Re: Tig Cooler water temerature?
    Or
    Water temps coming IN/OUT of the cooler....
    Hypertherm PM 45
    HTP 221
    Jul 2013
    For me it's room temperature out and return is up to ~140 F if I'm running hotter, 150-200 amps. It's probably more like 100-110F at 100 amps. My flow is also probably on the low end so it runs a little hotter due to that. Room temp for me runs from 45F in the winter to 90F in the summer.
    CT
    I don't have numbers for you, but my CK superflex hoses never got hotter than lukewarm to the touch. So maybe 100-ish degrees?
    Mar 2005
    Under a Rock
    appreciate it fellas.
    Hypertherm PM 45
    HTP 221
    Mount Tabor VT
    I haven't measured. When I first bought my present welder I was welding aluminum near every evening. Might weld an hour at a time at 150 amps or more. When I first got it, the cooler was back ordered. I wasn't going to wait 2 weeks to try the welder. I hooked it up to the sink water. I didn't bother to pipe it back to a drain, it just piddled into a bucket. It's a while ago now, but if I recall correctly, it took most of an hour to fill the bucket. It was warm to the touch, not hot, maybe 110 F.
    Mar 2005
    Under a Rock
    Not a big deal
    I was putting together this cooler and ran low on tubing...
    had some other clear 5/16" tubing... rated at 175į
    but I reconfigured things and I'm set with the HD hose
    was just curious
    Hypertherm PM 45
    HTP 221
    Laredo, Tx
    The clear 5/16" tubing will work but will balloon a bit more than the one with braided reinforcement, so it loses a little pressure.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Mar 2005
    Under a Rock
    I disagree.
    I think at the standard pressure that a water cooler runs/50 psi
    There is absolutely no ballooning or expanding of the line.
    The water pisses out the end of the hoseÖ no expanding whatsoever.
    That said, as far as torch lines
    Yes there is some expanding of the line due to the pressure but it really doesnít affect the flow.
    (especially with these super flex lines)
    Edit
    I am more concerned with lines that will fit properly and with stand moderate heat.
    Hypertherm PM 45
    HTP 221
    Mar 2005
    Under a Rock
    Iíve got some braided reinforced line but itís overkill
    And frankly ridiculous for this application.
    Hypertherm PM 45
    HTP 221
    Mar 2005
    Under a Rock
    If you were talking about a closed pressurized system, yes I understand about expanding lines etc. etc.
    But for a TIG cooler, there is no pressurization of the line
    Itís basically in and out.
    You can have your exit hose dump out into the open air and your pump will still maintain the same pressure
    Hypertherm PM 45
    HTP 221
  12. Likes rhunt liked this post
  13. #12
    Mount Tabor VT
    I would be very surprised if you ever had a tube failure associated with pressure or heat. I don't believe it takes more than a few pounds to push coolant through a torch. I also don't think coolant gets very hot.
  14. #13
    Mar 2005
    Under a Rock
    Well yeah that was Like my original question..
    Maybe I will buy one of those temperature sensors with the probe and mount it on this new refurbished re-constitutionalized revamped cooler.
    Itís pretty cool to just glance at it and know that the water is flowing
    Might be just as cool to glance over and see what the temperature is.
    It couldnít hurt and also a heads up to shut things down.
    I just replaced 25í torch lines.
    Not cheap.
    Especially when itís beyond your control and itís out of warranty to boot.
    Hypertherm PM 45
    HTP 221
  15. #14
    Laredo, Tx
    I'm just going by what I see when I turn on the cooler and can visually see the lines expand just a smidge.
    Run your tig on DC at over 200A continuously over 5 minutes and report back. It's not too "hot", but it does get very warm, so I guess it depends on the cooler and ones perception of what is "warm" and what is "hot".
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  16. #15
    Mount Tabor VT
    I bought a 1984 Dialarc 250HF with cooler. One evening I was wet. Warm water was coming from somewhere! A couple drops at first, then more. It proved to be the torch plugged, the supply hose failed. It was old. I went after the torch with several cleaning methods, never had a problem again.
  17. #16
    Mar 2005
    Under a Rock
    WHAT LINES?
    The internal lines coming from the pump to the torch in/out? and the radiator in/out?????
    If so, I call BS
    I have the same cooler, those lines DO NOT flex.
    If you are talking about the CK torch lines, Yes.. they will expand.
    But it does not have an effect on overall flow.
    : Nature of the beast.
    Hypertherm PM 45
    HTP 221
  18. #17
    Laredo, Tx
    Yes, those same lines, the ones inside the cooler. I guess it's just my cheap chinese hose replacements that flex, I dunno. So yours are better than mine; I can accept that.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  19. #18
    Mar 2005
    Under a Rock
    My lines are the stock HTP lines.
    braided 8.5mm lines.
    less than 30PSI is not flexing those lines.
    Hypertherm PM 45
    HTP 221
  20. #19
    Pensacola , Fla
    When I built my cooler I found info the showed the flow rate, don't remember what it was. But something like how long it took to flow X water verse time. The ProCon pump has a by-pass for adjusting the flow.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  21. #20
    Pensacola , Fla
    PROCON vane pump...
    You need pressure and flow that a pond pump simply cannot deliver...
    Your best bet is a vane pump like a PROCON carbonator pump..that makes 50-60 PSI & flows 3-4 Quarts per minute...
    Here is a build thread you might find helpful..
    http://www.shopfloortalk.com/forums/...ad.php?t=39374
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  22. #21
    Laredo, Tx
    PROCON vane pump...
    JohnT already has his setup going.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  23. #22
    Mar 2005
    Under a Rock
    Procon makes pumps specifically for TIG welderĎs you can find them on the arczone site.
    That said,
    You can most definitely use a carbonator pump, but you will need to swap out the bypass spring.
    If you donít you will blow the hoses right off your tig torch.
    I am using a carbonator pump on mine
    I called procon and they sent me the proper spring free of charge.
    Hypertherm PM 45
    HTP 221
  24. #23
    Whether lines expand or not would neither affect the flow or pressure.
    The lines expanding only happens once initially after that nothing is different.
    A expanded line would flow MORE if anything.
    It has larger I.D. Lol.
  25. Likes trboxman liked this post
  26. #24
    Apr 2020
    Coolant going in at room temperature
    Coolant can get up to 250f or so on the return, no need for a temp guage, you can feel the boiling coolant when its time to back off
  27. #25
    Mount Tabor VT
    Quote Originally Posted by 2strokeforever View Post
    If it's that hot I'd say there is something wrong.
Page generated in 1,623,614,360.12026 seconds with 12 queries
