Results 1 to 20 of 20
Thread: Camera Mount
    Mar 2014
    Troy MI
    Camera Mount
    This project was to build a mount for a forward-facing camera for a power boat. The camera mount will attach to the bottom of the roof of the cockpit. The channel detail will be mounted to the bottom of the roof of the cockpit and will support the cables that go to the camera. The purpose of the camera is to provide excellent forward visibility even when the boat occupants are in sub-optimal locations. The first picture shows my friend and customer Ray holding the completed camera mount. It is ready for powder coating.
    1. Camera Mount
    Name:  1. Camera Mount.jpg
    This was mostly a machining project, but I did have one weldment. Unfortunately, the weld maxed out my Miller Dynasty 200 DX welder. The foot was Ύ” x 1” x 4” Aluminum and the channel was 1/8” x 1” x 2”. I used the following parameters for the TIG weld:
    A/C Current output: 200 amps.
    Balance: 70% Electrode Negative
    Frequency: 50 Hz
    Electrode: 3/32” Tri Mix from Arc Zone.
    Shielding Gas: 75% Argon 25% He
    Shielding flow rate: 15 CFH
    Below is picture of one weld and a second picture of the entire 8’ weldment:
    2. Foot welded on
    Name:  2. Foot welded on.jpg
    3. Entire channel
    Name:  3. Entire channel.jpg
    The next picture shows the access cover removed to gain access to the cable.
    4. Access cover removed
    Name:  4.  Access cover removed.jpg
    And here is the access cover installed.
    5. Access cover installed
    Name:  5. Access cover installed.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
  2. Likes William McCormick liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Camera Mount
    This is a picture of the camera mount all done.
    6. Camera mount done
    Name:  6. Camera mount done.jpg
    I used my Bridgeport for most of the work, but I used a router table to make the radii on all of the parts:
    7. Router table setup
    Name:  7. Router table setup.jpg
    Here is a view from the camera. (As you can see the boat is still in its winter storage.)
    8. The cameras view
    Name:  8. The cameras view.jpg
    Here is a front view of the boat. The camera mount will be installed on the bottom of the roof of the cockpit.
    9. Front view of boat
    Name:  9. Front view of boat.jpg
    Last but not least here is a side view of the boat for perspective.
    10. Side view of boat
    Name:  10. Side view of boat.jpg
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  4. Likes Shootr liked this post
  5. #3
    Feb 2009
    Central CA
    Re: Camera Mount
    Maybe I don't understand how this whole thing is supposed to work, but it looks to me like every component of the project was designed to capture and hold water around the cable.
    Tim
  6. #4
    Mar 2014
    Troy MI
    Re: Camera Mount
    Quote Originally Posted by timrb View Post
    Tim
    Here is Ray’s response:
    Don, the camera mount and cable tray are going to be mounted on the top of the hard top, not the bottom. So the cable would be protected from the elements. Mostly the sun. The camera
    Will be hanging down.
    This is the view of my stern camera as seen on my Garmin GPSMAP 7612.
    The new camera will be viewed in a similar fashion. My iPad or iPhone can connect to this device so I can see the camera image when not at the helm. Also I can change the heading of the auto pilot when trolling.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  7. #5
    Arizona
    Re: Camera Mount
    Yeah, I'm gonna have to go with the theory that the camera manufacturer probably planned for water exposure, seeing how it was designed for boating. (FLIR-type system?)
    And I'll bet a nickel to a dollar I couldn't slide a gnats a$$-hair between that cord cover plate and the mount.
    Yeswelder MIG-205DS
  8. #6
    Dec 2011
    Tampa FL
    Re: Camera Mount
    In my experience it is often better to make items like this so the water can come and go as it pleases, sometimes trying to seal things up just causes water to get trapped.
    Mike
  9. #7
    Sep 2014
    Re: Camera Mount
    Quote Originally Posted by Don52 View Post
    1. Camera Mount
    Frequency: 50 Hz
    2. Foot welded on
    3. Entire channel
    If you clean the aluminum nicely, make sure it is a perfect fit up, you can use Straight polarity DC or DCEN. Do not pay attention to the slag that forms on the weld, just poke the welding rod into the molten puddle cook it in and move slightly forward and repeat. You can weld 1" thick aluminum like that. The bead is small but extremely strong. You have to wait till the heat builds up in part though before you start adding wire. I would suggest a practice piece before you try it on something you have a lot of work in. I have welded hundreds of feet using that technique it is an extremely strong weld, stronger than an AC weld.
    Sincerely,
    William McCormick
  10. #8
    Mar 2014
    Troy MI
    Re: Camera Mount
    Sincerely,
    William McCormick
    Thanks, I will give it a try.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  11. #9
    Re: Camera Mount
    Ya think they used stern cameras back in the day??
  12. #10
    Mar 2014
    Troy MI
    Re: Camera Mount
    What a beautiful boat.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. Likes farmersammm liked this post
  14. #11
    Mar 2021
    Near Roanoke, VA
    Re: Camera Mount
    I was on a 3,400 ton destroyer in the US Navy,, back in the early 1970's,,,
    We had no cameras,, and I do not remember seeing a rear viewing watch person,,
    There may have been one,, but, I hardly ever remember that ship operating in reverse,,, so maybe rear "eyes" were not needed?
    We did have a rear bridge,, and there was usually someone up there. (most of the ships controls were duplicated there)
    Maybe that guy looked back if needed?
  15. Likes farmersammm liked this post
  16. #12
    Re: Camera Mount
    -Don
    It's the Morgan https://www.mysticseaport.org/explore/morgan/
    Was one of the first plastic model ships I built as a kid, that's why I remember it.
  17. Likes William McCormick liked this post
  18. #13
    Re: Camera Mount
    We romanticize the old ships, but if you ever go on one, you see how they lived on those things. I can see why the press gangs had to be.
  19. #14
    Re: Camera Mount
    I've looked at some ships logs from that time, and you'd be amazed at how many people went overboard. YOU HAD TO GET ALONG WITH YOUR MATES IN THOSE DAYS, OR YOU'D BE TREADING WATER.
  20. Likes William McCormick liked this post
  21. #15
    Re: Camera Mount
    Anyways...........I like your work. Sometimes I bust your balz, but it's all for fun.
  22. #16
    Re: Camera Mount
    in fun
  23. #17
    Mar 2014
    Troy MI
    Re: Camera Mount
    Thanks for the link. I enjoyed reading about it.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  24. Likes farmersammm liked this post
  25. #18
    Mar 2014
    Troy MI
    Re: Camera Mount
    And this is what it looks like powder coated.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  26. Likes ccogg, Shootr liked this post
  27. #19
    Nov 2014
    PDX PNW
    Re: Camera Mount
    Sincerely,
    William McCormick
    Definitely not dc positive, maybe on some thin stuff like 16 gauge. 1/8 tungsten can only handle about 85 amps or so. And on negative you need helium to break the layer on the aluminum that the ac cleans and eats through.
  28. #20
    Nov 2014
    PDX PNW
    Re: Camera Mount
    I do apologize for insulting your intelligence William! Yes you are right it can be welded on dc- It did weaken the base metal a lot. Very easy to bend after welding, little tricky to get the rod in right tooName:  BA1B797E-F8B5-48E2-A378-A22F80047EC9.jpg
Page generated in 1,623,549,122.74996 seconds with 13 queries
