Results 1 to 21 of 21
Thread: Argon or other shield gas for getting started with TIG?
Hybrid View
    Jul 2020
    When I was at my LWS the other day I got a price on a 25/75 mix - ~$240 for the tank and $30 for the gas. The tank was described as an "RO" size. I haven't been able to get a clear description of the size, but I believe RO is 125cu ft?
    At the moment I only have DC TIG, but down the road I'd like to get AC for aluminum.
    I've read a few posts/threads around the 'net and most people that post up about tanks/sizes have some perspective on the larger tanks being the ones to upgrade to or go to off the bat because they have more gas and the refills are overall more economical.
    Just starting out and looking in to trying out TIG the RO tank at the LWS is way bigger than I'd like to have around - its about 4ft tall, maybe taller.
    What are your thoughts? I'd like to get a small tank, mostly for the storage and portability of it, but I don't want to short change myself much.
    Is there a mix of gas that would be best to go with? 25/75? 100%? I've heard guys going to helium also. All I'd be trying TIG with for now would be steel (might try alum on some scraps just for the heck of it, but I realize its not a viable process = not recommended). With alum in the future would that change up the gas much? Or maybe at that point swap tanks/type of gas?
    Aug 2018
    'ta town, KS
    Re: Argon or other shield gas for getting started with TIG?
    100% argon... is all you need for almost everything. There are needs for mixes, but for the most part 100% argon.
    Mac
  3. Likes FlyFishn, stevewatr liked this post
    If by 25/75 you mean 25% CO2 and 75% Argon, then you definitely can't use that to TIG weld, at all.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jul 2020
    Reason I was there was to get some rods so I didn't have gas on my agenda, other than to ask about it - which I did. That 25/75 mix is what the guy recommended - and with the information that I had DC Tig and wanted to try it. So I suppose I am not sure why they would make that recommendation if that mix can't be used with Tig?
    Ok so you that guy is not so bright. Argon for Tig.
    Simple, he just doesn't know. Good thing you didn't buy it.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  8. #7
    Let me guess: Airgas?
    Argon or helium for tig, or a mix of those two and nothing else.
  9. #8
    Sep 2005
    Cave Creek AZ
    FYI, the 25/75 gas is for MIG welding.
  10. #9
    I wanted to weld stainless. Manager at Bennington Airgas sold me stainless mix for MIG. He assured back purge could be any gas. He was wrong.
    Later, he said about the same about TIG stainless. He was wrong.
    ALL TIG needs argon. When you can't manage the power needed (I think aluminum BIG stuff) a mix of a bit of helium boosts the power of your machine.
    In my youth I heard of Heliarc welding. Helium gas, sine wave 60 cycle power was used to weld aluminum & magnesium & alloys. Based on the items I saw finished product it was amazing.
    Now, nobody can afford helium. 50 years they have developed welders that'll do as well on argon as primative welders did on helium. We make do with argon until argon won't do. Then we mix a bit of helium. It is amazing how well it works.
    I once needed to weld 5/8" thick aluminum with 280 amp max. I tried helium mixed about 3 to 1 with argon. Joints prepped to a knife edge one piece, square edge the other, probably open root 75 degree bevel welded beautifully! I welded from each side. Second side had almost no smuts to clean up where the first had been welded.
  11. #10
    Sep 2016
    Detroit, Michigan
    I started out with a 125CF bottle for TIG and found I went through it too quickly and traded it in on a 330....the difference to fill one is only about $20 more for the bigger bottle that has almost three times as much gas. A 125 is right at 4ft tall. I have an 80CF for when I want to take my smaller machine mobil, or bring it into my basement (rather than my shop building) but it doesn't take long to empty an 80CF at all, and it takes up the same amount of floor space as a 125 does....similar diameter, just shorter. I can't imagine getting anything smaller than an 80 and can't even imagine having to live with that small a tank as an only tank.
    As a hobby welder a lot of my projects are on weekends when the gas suppliers are closed, so I keep at least two 330s of everything on hand...one runs out and I have plenty of time to swap it out while I use the other.
    http://mivise.com
    Everlast PowerTig 210EXT
  12. Likes Oscar liked this post
  13. #11
    Yup, even a small TIG project will use up a lot of argon, especially with a lot of starts/stops that use pre/post-flows
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  14. Likes G-ManBart liked this post
  15. #12
    May 2007
    tig and mig, sound alike, i think better chance someone wasnt speaking or hearing clear. when i phone places in the midwest/south, sometimes i have hard time understanding cuz of there accents.
  16. #13
    Fredericksburg, VA
    If both of you were wearing masks inside the store, it is entirely possible for confusion to set in since like 123 said, TIG and MIG sound similar.
    100% Argon for nearly all TIG.
    Miller Spectrum 625 Plasma
  17. #14
    May 2011
    I have 2 local suppliers and you can buy a 3 foot tall bottle from 1 and the other will sell you a 4 foot tall bottle.
    I suggest you get the biggest bottle you can purchase as 4 or 5 yearly rentals covers the whole price anyways. If you want easy portability, get 1 of each bottle as constantly filling small bottles gets expensive.
  18. #15
    Apr 2020
    pekin, IL
    The small bottles are convenient for portability, but you'll probably want more than one. As a hobbyist I started with 2 - 42cf tanks of argon for welding aluminum with mig. All I had at the time was a spool gun setup and it worked. Then I got into tig welding and found I was going through those little bottles fast. So fast that my supplier ran out of the 42s so I got upgraded to an 80 and a 125 because that's the only sizes they had available at the time. Luckily it only cost me the gas price for those cylinders. I wouldn't recommend anything smaller than an 80 because you don't get a cap to protect the valve so transportation instantly gets more risky.
Page generated in 1,628,056,323.74243 seconds with 12 queries
