Results 1 to 8 of 8
Thread: Regulating hand plasma air supply
    Jul 2016
    So I got a Lincoln Tomahawk 625. Getting everything set up....
    I have a regulator/filter/dryer combo coming off the compressor.
    Iíve attached necessary manual pages below...this is what I gather...
    1) Air coming into the back of the machine, should not exceed 110 psi
    2) I use the regulator on the machine to get to 75-80 psi for cutting
    3) 1 and 2 mean that if I want to run over 110 psi on my shop air for other tools to use concurrently with plasma (eg. 90į die grinder for dross cleanup), Iím gonna need a second regulator dedicated to the plasma line, so I donít have to keep adjusting main regulator?Name:  A89B6BD1-B16F-4DC7-868A-0ECC39FB4D8B.jpg
Size:  147.2 KBName:  19398C39-4D1D-4265-A63B-599DCFD6E6B1.jpg
    Here it is standing: atoms with consciousness; matter with curiosity. Stands at the sea, wonders at wondering: I, a universe of atoms an atom in the universe. - Richard Feynman
    Sep 2005
    Cave Creek AZ
    Re: Regulating hand plasma air supply
    You will find that most air tools say 90psi max. I keep my secondary regulator at 90 and adjust as needed.
    Jun 2014
    Quote Originally Posted by Laggy View Post
    To answer your question- Yes. if you want to maintain two different output pressures from your compressor you are going to need two separate regulators.
    Jul 2016
    I think Iím gonna keep it simple cause Iím stupid. Iím never really going much above 90psi. Not looking to just throw money in the trash these days even if itís on a $20 regulator. Thanks for responses.
    I don't think it's a waste if you get a filter/regulator because what you really need is "clean" regulated air, especially when it concerns water vapor. Depending on the length of your hoses and size, your regulated line may not be the same pressure at the machine as the regulator, a regulator at the machine fixes that. All my shop air is regulated, filtered and has water reduction methods built in, but my plasma still has the regulator/filter on the back.
    Cut 50 Plasma
  6. Likes CAVEMANN liked this post
  7. #6
    If you keep your air at 90 coming off the compressor, it should have an easy time running 75 at the plasma cutter. I never have air starvation issues with mine. Just a simple 80gal compressor.
  8. #7
    I would put a dedicated water separator on anything to do with a plasma torch. Something like this or similar.
    https://www.tenaquip.com/product/mot...4aAhNLEALw_wcB
  9. #8
    Pensacola , Fla
    This is what I use on my CNC plasma table to dry the incoming air, I reverse the flow and fill it with silica gel. There is a kitty liter that is silica gel for a cheap filling.
    https://www.lowes.com/pd/A-O-Smith-A...tem/1000576415
    similar to how I do it. but I have a bigger dryer.
    this one shows the larger filter I use for the plasma.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
Page generated in 1,623,864,189.45998 seconds with 13 queries
