Results 1 to 12 of 12
Thread: Drilling Metal
    Sep 2020
    Lima, Peru
    Lightbulb Drilling Metal
    I'm an Disabled American VET living in Lima Peru. Just got ito welding out of necessity for a workshop I'm building. [https://freeimage.host/mrgfc/?list=i...3&seek=Kpl1oP]
    I have watched video after video on building stuff... welding, bolting, and drilling. I see people drilling holes with these:
    Name:  1 step bit.jpg
    all day long like a hot knife through butter. Can anyone link me a website that sells a good set of these, please. The set I found here dulled after the first use.
    Regards,
    Mr.C
    Re: Drilling Metal
    You can reshaping that type of cutter.
    It is a sheet metal drill typical found at AC suppliers and electronics suppliers.
    Quote Originally Posted by Mr.GfC View Post
    Regards,
    Mr.C
    Sep 2020
    Lima, Peru
    Re: Drilling Metal
    Um, I know you've been a member for a long time and have lots of posts, but I have to disagree with you that this bit is just for sheet metal.
    Here is a link to a that shows what I mentioned before "I have watched video after video on building stuff... welding, bolting, and drilling. I see people drilling holes with these all day long like a hot knife through butter. "
    Jan 2015
    Martha Lake, WA
    Re: Drilling Metal
    Not just for sheet metal - they are great when you want a tapered, stepped hole in thick metal..
    Joking aside, they are also called unibits - check out the section on them in the drill bit wiki. Mostly for sheet stock in gauges thinner than the width/length of the steps
    https://en.wikipedia.org/wiki/Drill_bit#Step_drill_bits
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
    May 2010
    ct.
    Re: Drilling Metal
    Those Unibits are best used in fairly thin material
    because each step on the bit is short. I like them
    for drilling in electrical panels because with only
    one Unibit and a set of knockout punches,I can
    make any size hole I need up to 2”. ( I don’t really
    like using hole saws in steel).What I don’t like about
    them is the cost and the fact that when the tip
    dulls, the whole bit is useless, unless you use
    a twist drill to start the hole. They also have a
    tendency to grab when one step breaks through
    and the next one starts. They cut pretty fast, but
    I don’t know if I’d say “like a hot knife through
    butter”.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Sep 2008
    Dalton, GA
    Re: Drilling Metal
    Go slow and use oil. As said, best on thinner stock 11 gauge max (in my opinion, not trying to start an argument).
    From another old vet.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Re: Drilling Metal
    Unibit step drills will bore through thicker (10 gauge + ) steel like a hot knife through butter ... until it doesn't. LOL
    Re: Drilling Metal
    Use screw machine drill bit for 18 gauge and up.
    Easy to to re-sharpen I would buy this type by the gross to keep the cost down.
    I would start with 3/16" pilot hole then drill up to 11/16" hole size.
    Re: Drilling Metal
    Uni-bits are for sheet metal cabinets mainly as they were originally designed but then the Chinese saw the value in making them a house hold item.
    They can be used in what ever you want to use them in. Obviously if you like the results for what your doing by all means but they were meant for sheet metal.
    To get any of them worth owning you have to pay the price for a good one. Most run of the mill Ebay Amazon cheap junk it going to be pretty worthless unless all you work with is plastic and even then it will never function like a quality piece will.
    Plan to pay something like $50-$90 or thereabouts depending on the size your looking for.
    I own several high quality cobalt ones from Irwin and Greenlee but for me personally I almost despise them. They just suck for most everything IMO.
    I prefer to use the Greenlee hydraulic knockout punch when I want clean accurate holes in sheet metal cabinets or whatever it is. If it is smaller holes use a regular bit and if it odd size or whatever I use a hole saw.
    Holes saws I have ever bit in every arbor I have replaced with hardened steel rod NOT a drill bit. That way you use a drill bit separate in the drill to make pilot that way the rod holds the holes saw true while you making the hole. A drill bit pilot bit just wallers out the hole and can't keep hole saw on track.
  10. Likes 12V71 liked this post
  11. #10
    Re: Drilling Metal
    Damn that was a little hard to read. Sorry guy's was in a hurry and didn't proof read. Lots of mistakes and can't edit nothing.
  12. #11
    Re: Drilling Metal
    It is happens to me.
    If on computer it does happen but smart phone it not so smart.
    I forget to prof read all time and with autocorrect and big fingers on the smart phone 📱 look out.
  13. #12
    Minnesota
    Re: Drilling Metal
    Smithdoor (Dave), I understand where your coming from about the big fingers (I have the same problem) but the way you string sentences together sometimes makes no sense and are hard to interpret. Sorry, just an observation.
Page generated in 1,624,385,903.86271 seconds with 13 queries
