Results 1 to 9 of 9
Thread: Cutting Disassembling Steel Grate
    May 2017
    Long time reader, Great people here!
    Thanks in advance for any help you can give me
    I have a 48 x 48 steel bar grate that has 2 sides of 1/4 bars with 3/16 bar sandwiched between to join them
    I'm trying to remove the bars from one side and reorient them on the other side
    The goal is to make the openings smaller and lighten it a bit
    I've tried a cutting wheel, recip saw, and plasma torch. All of which have their upside and down sides in time and consumables
    I realize that this may just be the nature of the beast, but I just feel like I'm missing something obvious
    If anyone has any experience with grates, maybe you could give me some suggestions
    Thanks!
    Sebeka and Bemidji MN
    Re: Cutting Disassembling Steel Grate
    Buy more material (1/4" rod is cheap), cut more bars and weld them on the other side.
    On second thought, just make a new one - way faster
    Syncro 350
    May 2021
    Landrum, SC
    ^^^Dave has a good idea there^^^
    Unfortunately there in really no easy way to do what your doing the way your doing it or an easier way to do it.
    Lincoln 330 MPX
    Modified Tombstone
    Lincoln Activ8X / LN-25X-TVT
    Magnum PRO 250LX GT Spool Gun
    Ton of Torches OFC-A / OFG-A
    SMAW FCAW GMAW
    May 2017
    That's what I thought, just didn't want to overlook something obvious
    Dec 2003
    Fairfield,CT
    Yup.. Make a new one.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    May 2017
    I just keep thinking about the wire pipe cutters but I've never seen one done in a portable
    Something like a portable band saw
    Anyway, thanks again to all
    Quote Originally Posted by mreinsmith View Post
    I just keep thinking about the wire pipe cutters but I've never seen one done in a portable Something like a portable band saw
    The 1/4" bars would be "easy" to snip off with some large bolt cutters, and then you'd just be left with grinding down the stubs where they're welded to the main body. The problem is that you're then left with a bunch of short bits that aren't really reusable to fill in the other side. Of course, buying some 1/4" round bar in long pieces is cheap and easy, so it's not like you absolutely have to use the cut-offs to do the filling in.
    What will be its use. It it must be used then i would use a thin cutoff wheel. Cut vee notch at the weld. Seem like as much work as removing them in pieces.
    It has not been my experience that making grating is easy. Fixturing, spacing, checking , rechecking, bending distorted bars, then discovering you were 1/8 inch off and the last bar shows the difference.
    May 2017
    I have several of these, so at the moment I am making a equipment storage cart and shelves
    I also wanted to make a plasma cutting table (although the powder coating burning off might be a an issue with that)
    Cutting off the bars around the perimeter is fairly easy
    That should give me enough to make add to the grid, for the rest I'm just going to cut them off to save weight
    I am going to try the V Cuts because that might actually help lining them up when rewelding
    I had an old stick welder that I donated to a friend of a friend. I'm kicking myself now because it had an attachment for "fusing/melting" bars together (I forget what they call that process)
    That would have been helpful DOH!
Page generated in 1,631,953,847.46208 seconds with 12 queries
