Results 1 to 14 of 14
Thread: how do I get/make rollers for weld coupon test bender
    Apr 2017
    placerville, CA
    Hi All.
    I plan on building a weld coupon bend tester, similar to the attached diagrams and photos. how can I get or make the rollers?
    1. Can I buy the two rollers “off the shelf”? (this would be easiest approach i think). i cannot locate a seller. i think they should be hard steel. They need to be at least 1.75 inches long (since the coupon width will be 1.5 inches. Can you tell me where I can buy these? Roller diameter should be 1.5 inches, or more. I searched for a seller without success.
    2. If these rollers cannot be purchased, how would you make them? I am thinking 4030 steel tube cut to 1.75 inch length. I do not have a lathe or way to machine them. do i buy a bushing that goes between the steel tube and a bolt? would it need to be a tight fit? or would a loose fit be okay? where to buy bushings? what type? solid brass? or should i use needle bearings inside a tube? i have never done bearings before.
    i know i could weld in some fixed non-rotating “rollers” on the shoulders of my fixture (such as wrist pins, or solid rod), but i prefer to utilize rollers that will actually rotate.
    i am hoping you can help me find where i can purchase rollers, or how to make rollers. any ideas or advice would be appreciated. thanks.
    Arizona
    Re: how do I get/make rollers for weld coupon test bender
    No idea if this will help, but for my work (conveyor repair-commercial) Omni Metalcraft makes our rollers and pulleys.
    https://omni.com/products/conveyor-rollers/
    They custom make just about anything we come up with. Wall thickness, diameter, length, axle size, bearing type, etc.
    If a roller won't work, possibly one of their pulleys.
    Yeswelder MIG-205DS
    May 2007
    [QUOTE
    1. Can I buy the two rollers “off the shelf”? (this would be easiest approach i think). i cannot locate a seller. i think they should be hard steel. They need to be at least 1.75 inches long (since the coupon width will be 1.5 inches. Can you tell me where I can buy these? Roller diameter should be 1.5 inches, or more.thanks.[/QUOTE]
    some dom tube w/ a bolt for shaft. i got some dom thats perfect for that. its ur 1.5"od, its got a .237 or .243 wall or something like that, so its got a lil clearance for a 1" bolt w/ a dab of grease on it. i got some 1.5" in .250 wall also, so if bolt shank is a couple thou under, it might be good too. u dont need hardened, buy a couple feet of dom, and ur set for life. " hangtown", yea
    Apr 2017
    placerville, CA
    123weld:
    "some dom tube w/ a bolt for shaft. i got some dom thats perfect for that. its ur 1.5"od, its got a .237 or .243 wall or something like that, so its got a lil clearance for a 1" bolt w/ a dab of grease on it. i got some 1.5" in .250 wall also, so if bolt shank is a couple thou under, it might be good too. u dont need hardened, buy a couple feet of dom, and ur set for life. " hangtown", yea"
    sounds like your 1.5 outer diameter tube with .243 wall would work good. (to show my ignorance, if i got your 1.5 tube with .250 wall, i don't know if 1" bolts are sold at under 1" or only at exactly 1"). let me check with McMaster carr on what diameter their 1" bolts have, and i will get back to you. i am definitely interested in your suggestions, and appreciate your feedback.
    Pretty much anything should work, just need the rounded corners. If your welds are good they won't crack or break. Tech school had a press in every lab. They pushed the coupons right through with a bit of a bang when they popped through.
    Quote Originally Posted by opa View Post
    123weld:
    Bolts solid unthreaded portion is under nominal size. A 1/4"(.250") bolt is .240" a 3/8"(.375) bolt is .360 so I would expect at a 1" size it would be a bit undersize like .960"
    Evidently that must not be true of them all. This chart list the shank diameters at larger than bolts nominal size. Odd because I just measured 20 bolts from all different manufacturers and all were smaller shank than bolt size. Be stupid to have a 1" hole and buy a 1" bolt and it be too big for hole. 1/4" bolt fit in 1/4" holes usually as do 3/8" so chart below seems whack.
    http://www.badensteel.com/bolt-dimensions
    "A" was the unthreaded shank diameter.
    Would it be too expensive to buy some large ball bearings and stack them on each shaft to make the rollers.
    3/4" I.D. https://bearingsdirect.com/ball-bear...-8x7-16-sealed
    10 of these are only $40
    1" I.D. https://bearingsdirect.com/ball-bear...g&results=3895
  7. Likes Shootr liked this post
  8. #7
    A very nice How-To from the fine folks over at Weld.com crew.
  9. Likes Shootr, Welder Dave liked this post
  10. #8
  11. Likes Welder Dave liked this post
  12. #9
    Hf pipe bender would be easily modifiable. Only need an upper die.
  13. #10
    May 2011
    The ornamental bender at HF has multiple sizes of the rollers you need. I know 7 ish years ago they were at least case hardened
  14. #11
    Apr 2017
    placerville, CA
    OP here. i have questions i need help on. i built a bend tester fixture, and i built a plunger that will press down on my welding coupons so i can bend test them.
    attached are two photos. they will be used with a hydraulic press.
    I used 4140 for the plunger. it came from McMaster carr and is annealed (i believe it presently has a rockwell c hardness of RHC 10). I welded the 4140 to a bar of 1018 mild steel (i used 312 tig rod). I will mount the plunger on my hydraulic press. but before i install it:
    questions:
    1. should i use the 4140 plunger "as is"?
    2. should i first heat treat the 4140 plunger (heat to austenitize and then quench ( in oil? in water?) and then temper it ?
    3. should i "case harden" the 4140 plunger with Cherry Red "instant hardening compound" powder instead of heat treating it ?
    i have never heat treated or case hardened steel before.
    my thoughts: the plunger is probably hard enough "as is" since it already has chrome-moly and .40 % carbon. but i would like to see what you all think. thanks for your feedback.
    Name:  bender w plunger.jpg
  15. #12
    May 2011
    If you aren't testing a lot of items, plain cold rolled 1018 or so is just fine. So you will be ok.
    If your a weld testing school, a tool steel would be best as you would want to wear out your tester on someone else's coupon.
    Maybe change your bolts to grade 8 or 12 depending on thickness, bug I would have made the bolts at least 3/4"
  16. #13
    It simple with little machinist back ground.
    I would look at bolts it simple and can done with out a lathe.
    Hi All.
  17. #14
    Feb 2019
    Snyder TX
    Just stack however many bearings you need to make width on a bolt. Find a bearing with correct outside diameter, say it is 1/2" thick, you need 4 of them on the bolt to make a 2" roller...
  18. Likes VaughnT liked this post
Page generated in 1,713,268,436.63788 seconds with 20 queries
