Results 1 to 12 of 12
Thread: Peashooter accuracy?
    Oct 2012
    Maryland
    Simply out of an abundance of curiosity - Has anyone seen (or performed themselves) an accuracy test of peashooters? As it seems nearly all versions are single manufacturer Chinese sourced not sure if there is a go-to brand with quantifiable accuracy.
    The backstory as to what has me wondering about this - I got in the habit of simply setting my Hobart dial gauge to 20cfh and adjusting up/down based on weld performance, in the end that's all that really counts anyhow. The other day I finally (nearly 2 years later) got around to fabricating a basic all-terrain welding cart which prompted I lose the barbed nipple from the gauge to be replaced by a proper B-fitting hose. Doing so I noticed the barbed fitting incorporated a .031 restriction for proper gauge calibration. I soldered an equivalently restricted plug into the required adapter so my gauge should still be reading proper. That said, I've decided to purchase a peashooter for double checking hence my initial query.
    Sebeka and Bemidji MN
    Re: Peashooter accuracy?
    I use one of the non-cheapo flow checkers, and it works well.
    Have I checked the checker?
    Not really - but three quality regulators/flow meters all read the same as the flow checker. So I "assume" they have all checked each other.
    Syncro 350
  3. Likes golem liked this post
    Dec 2008
    Ok, I'll bite. What the heck is a pea shooter?
    When I was a kid a pea shooter was a straw or tube that you would blow peas through like a blow gun!
  5. Likes 12345678910 liked this post
  6. #4
    city of Four Flags
    Over the nozzle/cup flow checkers.
    Slang.
  7. Likes welding1 liked this post
  8. #5
    May 2011
    A pea shooter is back in high school, shooting one one with a wad of paper through a straw. Accuracy was based on quality of wad and how hard you blew your load.... well at least I ended up fine compared to other who had kids lol
  9. Likes N2 Welding liked this post
  10. #6
    Nov 2012
    North Port Florida
    never heard "pea shooter" but its funny!
    It seemed like a good idea at the time!
  11. #7
    Oct 2012
    Maryland
    Thanks all! At least this thread provided a bit of levity. ;-)
    Funny thing is, for me, "peashooter" said in reference to welding provides instant understanding of the subject while saying flow tester/meter/gauge always requires a bit more fleshing out to know what exactly is being talked about. Pretty sure it's because the first time I ever heard about these at-gun flow testers it was called "peashooter" which gave me a chuckle as I looked it up to verify what the heck was being discussed.
  12. #8
    SoCal-LA
    Same here. I have an assortment of expensive ones(CK type) and el cheapo(eBay china) ones. About 10 in all, one at each weld bench, and they all read within a cubic foot of each other. All of my Victor flow meters are pretty dead on.
  13. Likes golem, MinnesotaDave liked this post
  14. #9
    Oct 2012
    Maryland
    MinnesotaDave & shovelon, appreciate the replies regarding experiences with the flow checkers. You'd think making even a budget Chi-checker relatively accurate probably shouldn't be a daunting task -- Sounds like that may be the case.
    What I like about the CK checkers is the scaling. Most (if not all) of the Asian branded have an extended scale usually greater than 50 CFPH (53-55 CFPH). I've not had opportunity to compare the two but if the CK is the same size as the cheaper imports the more appropriate 40 CFPH scale should inherently make it slightly more accurate and fairly easier to dial-in.
  15. #10
    Jul 2018
    Cumbria, UK
    I've never checked my peashooter accuracy... but what i dis a while back is play with flowrates on stainless TIG, and see what the least flowrate would give the best shielding results. I put a bit of my tape at the ball height. Now i know to set my flowrate to what I personally know is good, and repeatable.
  16. Likes shovelon, golem, rhunt liked this post
  17. #11
    SoCal-LA
    Quote Originally Posted by golem View Post
    These are the ones I buy from Ebay. https://www.ebay.com/itm/322275905270
    They are all accurate to each other and match my CK type for Argon. I never run pure helium anymore, just Arg75/He25, so I don't worry to much about calibration for the helium. The CK type is made in Italy. Bashed them both around and never broke one.
  18. Likes golem liked this post
  19. #12
    Oct 2012
    Maryland
    Thanks for the replies!
    That's a great system for quick and accurate checking/adjustment. I had contemplated using a sharpie tick for indoors and another as an outdoors starting point.
    They are all accurate to each other and match my CK type for Argon. I never run pure helium anymore, just Arg75/He25, so I don't worry too much about calibration for the helium. The CK type is made in Italy. Bashed them both around and never broke one.
    Clairvoyant much? The fact you linked to that tester is eerie, I ordered the exact unit last evening. Great to know it tests favorably to its peers. I wasn't hung up over the LPM vs CFPH option but figured for a couple $$ more, what the heck. ;-)
    It's funny to think the only reason I initially contemplated getting one of the flow testers is basically because I'm curious as to whether the Hobart dial gauge is still "accurate" after my restriction retrofit to the manifold-out adapter.
  20. Likes shovelon liked this post
Page generated in 1,627,457,985.01254 seconds with 12 queries
