Results 1 to 25 of 33
Thread: Welding a Trailer
    May 2021
    Welding a Trailer
    Okay, looking for info on what I need for welding a 4x8 trailer (for teardrop camper project) for a beginner. What type of machine/torch? I do know I need a mask, gloves, apron, etc. Looking into those now. I want to build either an aluminum trailer or steel. Prefer lighter because of tow weight. Cutting corners is NOT an option here.
    I don't want my camper to break off & roll passed me at a stop or down a hill. Heard stories of tires doing this (happened to my ex-father-in-law, his tire passed him at a stop sign). Also, a friend's trailer did this when they were on their way back, down a hill. That was a big mass produced camper...
    Videos & books recommendations will be accepted & looked into. No clue which to watch or what to read.
    On a fixed income, so I am saving up money for what I need as I go along.
    Thank you in advance for any info!
    Re: Welding a Trailer
    It's not good to post the same question in more than 1 forum. I responded to your introductory post. A trailer is not in the cards for you at this time. Too much liability and you don't have enough experience no matter what you read or watch online.
  3. Likes mcspeed, CAVEMANN, Albin liked this post
    SoCal-LA
    Quote Originally Posted by new_to_welding View Post
    So where the heck do you hail from? Classic newbie blunder not to disclose this. There are many members on this site that may be close enough to meet with and mentor you. Se my location opposite of my screen name?
    Anyway steel is the way to go for the trailer frame, alum for the cabin. Personally I would go tig and get every inch of weld inspected. If you are close enough I will do it for you.
  5. Likes Albin liked this post
  6. #4
    Mar 2005
    Under a Rock
    I don't want my camper to break off & roll passed me at a stop or down a hill..
    You are biting off WAY more than you can chew.
    BUY A TRAILER. then take some welding courses and practice practice practice.
    Trying to build a trailer right now is foolish and dangerous.
    lots of bad things can happen when welds fail.
    No need to put other peoples lives in danger needlessly.
    make a welding cart or some other small non critical project... not a trailer.... for crying out loud.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  7. Likes welding1, CAVEMANN, Albin liked this post
  8. #5
    SoCal-LA
    Baby steps!
  9. Likes Albin liked this post
  10. #6
    May 2021
    Alright. Thanks. I'll buy a new trailer. Won't be back.
  11. #7
    Sep 2005
    Cave Creek AZ
    Ta ta, we won’t miss you.
  12. Likes Albin liked this post
  13. #8
    Jun 2014
    Southern Illinois
    I just heard the screen door slam
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
  14. Likes Albin liked this post
  15. #9
    Sep 2016
    Detroit, Michigan
    Take a step back....nobody said don't start welding, they just said that what you're asking about is simply an unrealistic project now and in the near future. There's a lot more to something like a trailer than just laying down some beads....and I'm not talking about the engineering or specs. There are all sorts of things to learn when starting out, like fit up, holding angles, keeping stuff straight, etc, etc. None of that matters much if you're welding up a gate or a cart for your welder, but it matters a lot for something going down the road.
    If you don't come back....okay then.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  16. Likes CAVEMANN liked this post
  17. #10
    Mar 2021
    Near Roanoke, VA
    I ,, on the other hand, say build the trailer,,
    I bought the cheapest 225 amp stick welder the local supply had,, and built a woodsplitter,,
    sure, the wedge broke off,, but, it was a good lesson on how not to use 6013 rod to weld the wedge to the beam.
    I see DIY 4X8 trailers hauling trash almost EVERY time I go to the local landfill on Saturdays,,
    AND,, I am POSITIVE those trailers were first time DIY projects,,
    As long as you are reasonable in your expectations,, that Lincoln welder at Lowes,, and some 7018AC rod,, you will be building soon,,,
    Good luck.
  18. #11
    You probably can (and should at this stage) buy the trailer base cheaper than you can make it. Trailer talk here gets turned into trailer trash talk really fast here, don't take offense but do consider the advice. The link I'll post is in Canadian $$ so in USD it is probably less than $700 + tax. This type of purchase would remove a lot of liability for you and as I mentioned... save you money. Just use it as a base to build what you need.
    https://www.homedepot.ca/product/mar...ler/1001242090
    ---Meltedmetal
  19. #12
    Dec 2003
    Fairfield,CT
    Welcome.....Um.....Bye.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  20. #13
    Mar 2021
    Near Roanoke, VA
    The problem with that Home Depot trailer, by the time you add the needed lumber to finish it,, you can buy a nice Toyota truck for less,,
    maybe in Canada lumber is cheaper,, but,, here in Virginia,, ALL of my wood containing projects are on hold,,
  21. Likes walker liked this post
  22. #14
    Sep 2016
    Detroit, Michigan
    When his trailer has a failure it might be the tongue breaking off, not just a wedge on a wood splitter.
    Lots of people do stupid stuff, but it's still stupid stuff. Probably half the time I see someone pulling a trailer it's obviously loaded incorrectly, overloaded, not following laws for tie downs or all of the above....that doesn't make it smart because it's common.
    You're positive about something you can't possibly have any way of confirming? There's a term for that...it's called "guessing".
    http://mivise.com
  23. Likes Oscar liked this post
  24. #15
    The trailer thing always turns into a flame fest. In all honesty most " weld failures" are due to poor design or joint preparation rather than poor welds. I've done enough repair work to know that even a poor weld in the proper configuration is about impossible to break off, often requiring it to be cut almost entirely away. With that being said at least do several test joints and try to break them to check for fusion, penatration, etc.
  25. #16
    No, lumber in Canada is stupid expensive. My renovation project also went on hold. Around $105.00 CDN for one sheet of 3/4" plywood if you can find it. The wood cost are sort of immaterial though since he'd have to buy it anyway if he built the trailer from the road dust up.
    ---Meltedmetal
  26. #17
    Plywood jump last summer by 20% to 25% . It has goes up it tornado and hurricane season.
    That true with all lumber suppliers and every tornado and hurricane season.
    If need to buy truck load best time by is Christmas .
    Worst time is hurricane season it was starting in fall.
  27. #18
    With steel prices the way they are, building your own trailer would probably cost 10X as much -- in materials ALONE, not counting labor -- as buying a Chinese one from HFT or somewhere like that. Buh-bye!
  28. #19
    I build my own trailers as the light duty from China my let down if hauling steel.
  29. #20
    Jun 2017
    AJO, ARIZONA
    Wow, people are just trying to save you a bunch of possible grief, or maybe some lawsuits, or maybe even someones life or your life, grow up man!
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  30. Likes Cobraone liked this post
  31. #21
    Actually, and this isn't in defense of any particular position, the welds on commercial trailers suck. I mean SUCK. But, because there's a lot of redundant weld, it works(shrug)
    Same with most things. I see stuff that I absolutely know was done by certified welders, and I'm amazed at the crap work. Structural stuff subject to inspection.........crap welds. I mean it's depressing, and it's why we're evolving into a 3rd World Country. Be honest, look around out there, and see if I'm not right..........the work product sucks for the most part.
  32. #22
    Dec 2016
    why is this thread still going? elvis left the building .
  33. Likes walker liked this post
  34. #23
    city of Four Flags
    Dog pile on the trailer builder.
  35. #24
    Mar 2005
    Under a Rock
    Same with most things. I see stuff that I absolutely know was done by certified welders, and I'm amazed at the crap work. ..
    I was looking at the landscape type trellers at Cabelas the other day... and I thought they looked pretty nice actually.
    decent price too.
    But the OP wanted a teardrop camper so my point is pointless.... (just like the top of my head)
    anyway,
    can you imagine a complete "newbie" attempting to build an aluminum teardrop trailer?
    the guy doesn't even know which machine to buy.... good luck welding aluminum.
    Hypertherm PM 45
    HTP 221
  36. Likes Kevin_Essiambre liked this post
  37. #25
    city of Four Flags
    If you want to see crap welds explore the RV industry. Most of those welds are “as hot and fast as you can physically move”
Page generated in 1,635,264,143.14722 seconds with 12 queries
