Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Plasma table recommendations
    Apr 2021
    Re: Plasma table recommendations
    I don't have any videos. I don't really do videos. But I can share a couple pics of some stuff I cut out. I haven't done much with the table in a couple months. It's also time to clean the sludge from the water table.
    Sent from my moto e6 using Tapatalk
  2. Likes N2 Welding liked this post
  3. #27
    May 2011
    The JD2 with the hypertherm cutter cuts very well. The Z height works well and the magnetic quick detach is a very nice feature. I dont think you could get a better table for the price.
  4. Likes N2 Welding liked this post
  5. #28
    Sebeka and Bemidji MN
    Quote Originally Posted by liberty_metal_worx View Post
    I have a JD2 MAD 4x8. It is the model before they added the tube cutting.....thing. It is extremely well built. Servos instead of steppers really makes it a cut above most tables in its price range. The control board is made in-house. The interface PC is solid state of which I haven't had a single issue with in 4 years. The gantry is a one piece weldment. The table frame is over built. The stainless water table is impressive. The machine is VERY easy to operate. I really like the user interface software. It has real time control where you can pause the operation and choose your restart point anywhere you want. This is very handy when needing to grab a drop out that tips up in the path of the torch head. It uses SheetCAM which I haven't had any issues with. As with any good cnc system there is a learning curve and you have to be vigilant in learning the details of operation. From CAD to CAM to the table operation. No JD2 doesn't provide CAD software because they make cnc equipment not design software. I use QCAD, Inkscape, and Fusion360.
    I demo'd several plasma tables. I was almost ready to pull the trigger on ArcLight(which is a good option IMO) until I toured the JD2 facility. The tech support is a cut above the rest I believe. They will help you with anything period. I have made a couple dumb mistakes on weekends. Called and left a message and they always call right back. If it was my day off I wouldn't bother but Fred is awesome.
    The dude from JD seems very straightforward and normal - I like that
    Syncro 350
  6. #29
    Just like all the members here....
  7. Likes psacustomcreations liked this post
  8. #30
    I didn't go that far
    Syncro 350
  9. #31
    Syncro 350
  10. #32
    Hellinois
    tagged plasma table info
    "Stick-man"
Page generated in 1,635,014,146.58179 seconds with 12 queries
