First Time Welding: Any tips?
Hi, I just got my own welding machine. It is just an off-brand from amazon. It is YESWELDER MIG 205DS. Today, I get to use using the gasless flux core. Keep in mind this is the only method I am going to use for a long time since I do not have access to a gas tank.
Anyway, here are my first welds and let me know some tips or just critique it. Thank you!
Re: First Time Welding: Any tips?
If you never welded before that right there is a pretty good start for the first time, looks like you are pretty steady at it. I dont know anything about the welder you are using but it looks like you might be running a bit cold, thats what giving you the spatter, play with your heat settings or turn your wire feed speed down a wee bit and then move a bit slower. Keep your stick out from the tip steady too, evryone runs a little different find out what works for you and get lots of practice.
Again I say you lookin pretty good for weldin the first time
I would say INCREASE the WFS (and tweak the voltage to match) to deposit more weld metal and have it wet out a bit more (more voltage alone is not always a good thing). Those beads are tiny compared to the thickness of the steel, whatever it may be. Keep ½ to 5/8" stickout/CTWD and keep it steady. Keep tweaking things and practicing on scrap and you'll be able to fine-tune in no time.
I think a little cold too but very good for 1st attempt! Turn up wire feed speed and then turn up voltage so the puddle wets out better to the edges. Generally more volts makes for a wider flatter bead.
I have the same machine. The wire feed is set by the machine based on the voltage, you cant adjust it independently. I assume you know that there is a way to set the voltage by selecting the thicknesses of the metal, in mm, and it auto sets the volts. A few have suggested that the settings chosen that way are a little hot, so i normally choose a thinner thickness when setting that way. The welds will look much nicer, and will be easier to see what you are doing once you hook up a gas tank.
