Results 1 to 7 of 7
Thread: TIG weld undercutting?
    Nov 2020
    I am struggling with fillet welds on 0.040 inch (1 mm) thick copper. I had been using 1/16" (1.6 mm) TIG rods, deoxidized copper, starting to experiment with 0.045 wire. (It is a pain to straighten a spool of wire, but can be done with the help of a drill). I usually use pulse, and sometimes walk the cup. I consistently have trouble with undercutting, usually on the vertical side. Why do I only see it on one side?
    I am using test coupons of 1 inch by 4 inches. I melt the outside of the corner without adding rod, and then I go back and put in a fillet weld. Sometimes I try to do it without adding wire, sometimes I add wire. The purpose of the fillet is for appearance; this is an art piece, so strength is not a concern. The undercut is significant, and really mars the appearance. I sometimes see undercut on the outside; however, the appearance there is not as critical as on the outside.
    I have been working on process improvement, including measuring tungsten stickout. However, many hours of practice do not seem to result in improved results. I have made arrangements to have a private welding lesson from a young man who was recommended to me by a local welding shop; perhaps he will find something that I am doing wrong.
    I don't consider myself a great welder; I do not weld every day. I have been welding for many years, usually TIG welding. I believe that welding copper is a lot like welding aluminum, but somewhat more difficult, as copper is more conductive.
    Looking for suggestions. Thanks in advance.
    Richard
    SoCal-LA
    Re: TIG weld undercutting?
    Quote Originally Posted by richardferguson View Post
    Richard
    What gas are you using? I myself prefer to add helium to my argon for a hotter more focused arc. And ditch the pulse as it flares the arc. If you need some pulse to keep you AD hood dark, then max out main amp time, max out background amps, and lower background amps time percentage.
    You may only see the undercut on one side because one side has little mass to conduct the heat.
  3. Likes richardferguson liked this post
    CT
    I don't think you can do an inside corner without filler and not get undercut. Undercut, in my experience is from too much heat, not shoving in enough filler rod, and maybe wrong torch angle. I would put the torch more on the bottom side (which ever side is down towards the ground) since heat rises. The side with the undercut is likely getting too hot. If both sides are undercut, then you need to add filler.
  5. Likes richardferguson, shovelon, 12V71 liked this post
  6. #4
    Nov 2020
    I am using straight argon gas. I am not set up for helium
    It is possible that the undercut on the vertical side is because the flat side is against the welding table, which acts as a heat sink.
    Richard
  7. #5
    SoCal-LA
    Richard
    Yes, it is very possible. The vertical will saturate with heat much faster. You could try a lay-rod technique really cramming the rod in to keep the undercut filled and the puddle chilled.
  8. #6
    Me neither. Creating an autogenous weld on an inside corner creates a weld puddle that forms a radius between the two pieces. That metal has to come from somewhere.
    If you don't add any filler, you're going to get undercut. No way around it.
  9. #7
    Oct 2019
    Australia
    With tig, undercut is mostly underfill as others have said.
    I differ on the torch angle. The weld pool follows the heat, so I would angle the torch up a bit and add more filler from the top of the bead.
Page generated in 1,627,457,449.19414 seconds with 12 queries
