Results 1 to 10 of 10
Thread: Can I use propane or LPG gas for welding?
    Jul 2020
    Dubai
    Jul 2018
    Cumbria, UK
    Re: Can I use propane or LPG gas for welding?
  3. Likes shovelon liked this post
    Big Lake/Monticello MN
    Short answer and long answer are both no...
    I like it for heating and cutting though.
    Syncro 350
    Mar 2021
    Near Roanoke, VA
    Quote Originally Posted by shasti View Post
    Depending on what you are doing,, possibly brazing or silver soldering would work?
    With brazing, you could use propane,, especially if you buy a "TurboTorch".
    I have several sizes of TurboTorch tips, even the biggest T-6 tip, that torch is amazing.
    I believe I could braze 3/4 inch solid steel bar to 1/4X2 inch steel bar.
    Car body repairs should be easy,, and no acetylene is needed.
    If your parts are smaller, a smaller (lower cost) tip is adequate.
  6. #5
    Sep 2005
    Cave Creek AZ
    You absolutely can, just not in the manor these guys are thinking of.
    You just need one of these little honeys and you can weld with propane all day long!
  7. Likes 12V71, Dave66, farmersammm, Louie1961 liked this post
  8. #6
    I agree with MinnesotaDave.
    It possible to but will not give good job.
    I did try propane and oxygen one time when about 14 it was not good.
  9. #7
    Need a neutral flame for gas welding which is only possible with acetylene. What do think all extra oxygen from burning propane is going to do?
  10. #8
    Jul 2020
    Dubai
    Thank you for your advice.
  11. #9
    Mar 2021
    Near Roanoke, VA
    I thought a neutral flame was possible with any fuel, even charcoal,,
    IMHO, neutral indicates neither excess oxygen, or inadequate oxygen.
    If the flame is neutral, the flame is at its highest BTU output, and probably the highest measurable temperature.
  12. #10
    No. Actetylene is hottest with an oxidizing flame, 6300*F neutral is around 5850*F carburizing around 5700*F depending on how much O2 is added. Sometimes you see terms like 2X feather or 3X feather. That refers to the outer feather of the flame and is adjusted by the amount of O2. Only oxy/acet. can produce a neutral flame with enough heat to melt steel. Oxy/propane (or other fuel) can have a flame hot enough to melt steel but it is an oxidizing flame so won't produce a sound weld. For brazing where you don't melt the steel propane and other fuel gases can be used.
Page generated in 1,713,264,004.64043 seconds with 20 queries
