Results 1 to 15 of 15
Thread: 4 prong 50amp to 3 prong 50amp
    May 2013
    South of Dallas
    Both my welders use a 3 prong plugs. On nice days it would be nice to work under the carport, Where I have a 50 amp 4 prong plug. I have a 4 prong rv cord that Id like to put a 3 prong female plug on. Can someone explain to me how I can wire this?
    Re: 4 prong 50amp to 3 prong 50amp
    It is apples to apples except the 3 prong will drop the neutral.
    4 wire is 2 hots a neutral and a ground.
    3 wire is just the 2 hots and ground but no neutral.
    May 2013
    South of Dallas
    Thank you
    Los Angeles
    If you don't want to cut off the RV connector you can buy adapters.
    RVGUARD Welder Adapter Cord 12 Inch, NEMA 14-50P to 6-50R, 50 Amp Welder Adapter, Green
    on Amazon, $30.00
    MM211 (Sold)
    Klutch 120v Plasma cutter
  5. Likes whtbaron liked this post
  6. #5
    May 2013
    South of Dallas
    The cord I want to use is the twist lock style.
  7. #6
    May 2013
    South of Dallas
    Heres the plug
  8. #7
    Aug 2019
    Quote Originally Posted by Millwrightdude View Post
    I rigged the following. Preface, this is for 20 A emergency service off the generator. Got this idea from someone else. I had a second 50 A three prong box that I tied to the 4 prong 20 Nema twist. I braided the chord and tripled the mains to carry well above the 20 A. Works nice. Zero cost.
    Again this is only to have a welder or the carbon arc torch during power outages.
    I can take a better picture if interested
    Regards.
  9. #8
    Los Angeles
    Heres the plug
    Do you want to keep the twist lock style connector?
    MM211 (Sold)
  10. #9
    May 2013
    South of Dallas
    Not really
  11. #10
    Los Angeles
    Not really
    Cut that sucker off and put a 6-50 connector on it.
    Red-Hot 1
    Black- Hot 2
    Green- ground
    as Daniel mentioned , don't use the white neutral wire.
    use one of these:
    Forney 58401 Electrical Receptacle, Pin-Type, Portable 50-Amp, 250-Volt,Black
    MM211 (Sold)
  12. #11
    May 2013
    South of Dallas
    This is what I have ordered
  13. Likes Broccoli1 liked this post
  14. #12
    I went through the same thing with my PTO powered generator, but the 4 prong plug on it wasn't a twistlock. I needed an adapter in a hurry one day to use the buzzbox in the field so I put a 3 prong plugin on a foot of heavy cord with a 4 prong plug in. I've used it numerous times over the years and it's worked well. As mentioned above all you are eliminating is the bare copper ground.... the green, white and black going into your welder cord are still hooked up. I forget offhand whether the white wire goes to the skinny side of the plug or the wide one, but you can usually tell by the color of the screws.
    Cut 50 Plasma
    Los Angeles
    I'm not sure what yer saying here though. There are no bare wires in cords.
    He will need the Green Ground wire, Black Hot &
    Red Hot.
    The white neutral wire is the one not used
    MM211 (Sold)
  16. #14
    Ahhh.... I used a short chunk of household type wiring because I didn't need it to be flexible.... it was more than 25 yrs ago so my memory might be a little sketchy...
    Cut 50 Plasma
    We are dealing with 240 volt here. The white and the black in a SJ feeding a 240 welder doesn't matter which leg you put either one on. You are going to make it confusing when you don't need too. Wider or narrow blade are one in the same here. Two hots and a ground for 240 welder. The only one you need to place correctly is the green ground or if you used ROMEX or SE that one would be bare.
Page generated in 1,632,151,143.91176 seconds with 13 queries
