Results 1 to 25 of 46
Thread: Mixing Rustoleum with Rustoleum
    May 2013
    South of Dallas
    Can I mix these two together?
    Dec 2011
    Tampa FL
    Re: Mixing Rustoleum with Rustoleum
    I would not, according to the tech info on Rustoleums website those two paints have different recommendations for the solvent to use with them.
    Mike
    May 2007
    ill tell u one thing i wouldnt do w/ that farm rustoleum, and that is, mix a quart w/ a gallon. even though they got same part #, they are different. i found out w/ "old cat yellow". i didnt mix, just continued paiting. it was more than a slight discoloration form a different lot. rustolems final most logical explanation on it was, they can get away putting more oil/good stuff in a quart than they can a gallon. in other words, theres a less percentage allowed of alleged ozone eating vapors allowed in a gallon, than a quart. so i always buy it in quarts, no matter how much i need. also black, aint always black. chevy/gm black was black for yrs and into 80's, but in 90's, they started mixing tiny bit of yelow etc., in there black. i guess it depends on what ur painting on whether id mix the two
    Sure, just be sure to mix enough to do the job. Chances are 99 percent or more that the colors are slightly different.
    May 2013
    South of Dallas
    I will just use the full quart.
    You really need to pay attention to the labels now... some of the rust paints are oil based, some water, and obviously those won't mix.
    Cut 50 Plasma
  7. Likes 12345678910 liked this post
  8. #7
    May 2013
    South of Dallas
    I think these are both oil base
  9. #8
    Aug 2012
    AR
    To end all the guessing, why not just go ahead and mix a small batch of the two and let us know what happens?
  10. #9
    lol... that was going to be my next response as well... same brand and both oil I'm guessing it would be ok.... might be slight variance in colors but being black I doubt it would be noticeable ... both are supposed to be high gloss.
    Cut 50 Plasma
    May 2013
    South of Dallas
    I just finished spraying the can that was full. I might spray the partial can later.
  12. #11
    Where did you find that? I came up with all the hazardous product crap but no useful info.
    Cut 50 Plasma
    Dec 2011
    Tampa FL
    https://www.rustoleum.com/-/media/Di...prays_TDS.ashx
    It is the technical data sheets they are on the page that also as the SDS sheets.
    Mike
  14. Likes whtbaron liked this post
  15. #13
    Jun 2017
    AJO, ARIZONA
    I used to work for 2 different NAPA stores, one in the early 70's and the second in the early 80s, part of my job duties was mixing automotive acrylic enamels, to say that "black is black" is completely wrong. Blacks have always had different colors added fo "toning", the same applies to whites, at first it amazed me at the colors that got mixed in to "tone" it. The man that taught me had to color match a metallic teal on a 73 Chevy pick-up thay the transport driver managed to bash a door in, he mixed the color by the code & it wasn't even close, it took him 2 more tries but he got a perfect match.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  16. Likes N2 Welding liked this post
  17. #14
    May 2007
    i'm not "completely wrong", we were using terminolgy on an industry level of hardware/farm paint, till u come along. most us learned in kkindergatden about primary colors, and what used for. so i didnt need ur job of punching in numbers and jacking off paint cans at napa, to understand. i was giving an example to the orig poet, that black could be different, and used gm as an example. like i was telling member "iroczman", about painting my cars black. i painted my comaros w/ ppg #9700, which was, and probabaly still is there "black black, on industry terminology". at the time, gm was intentionally getting away from black black. and im not even sure black or white is a color (but i refer/think to it as) , and dont care to argue whether black or white is a color. i got other more important things to do.
  18. #15
    I had a ton of red paint, and a ton of yellow paint. Damn thing turned out PINK!!!!!!!!!!!!!!!!!!!!!!!!
  19. #16
    Years ago I worked for a sign company that also did highway billboards. Whenever we made new panels the backside needed to be painted to protect the wood. Leftover cans of enamal were dumped into 5 gallon pails and mixed. Seems like no matter what combination of colors that were mixed it always came out kind of a green- grey color.
  20. #17
    Jun 2017
    AJO, ARIZONA
    whatever.I wasn't trying to argue anything, just pointing out the facts that existed in my world.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
  21. #18
    Mar 2005
    Under a Rock
    Quote Originally Posted by Millwrightdude View Post
    NO
    Use either/ Or.
    Been there.
    On the subject of paint
    Tractor supply “majic” tractor truck and implement paint seems to work pretty good
    Along with their catalyst Hardner.
    Brush or spray
    BLACK PAINT MATTERS.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  22. Likes mcspeed, Freebirdwelds liked this post
  23. #19
    May 2007
    i gotcha. i was looking to end it quick, before it turned into one of them big run on threads w/ multi people. yeah, its good you got some experience in that auto paint (its tricky) and its always changing w/ new stuff/ways
  24. #20
    Jun 2017
    AJO, ARIZONA
    THANKS, it can be very frustrating, we used a shadow graph to measure by weight, I don't remember everything about it but it was as far away from computerized mixing as you can get, the old slide open can "valves" that HAD to function and you would activate them over and over to make sure, especially if mixing for a color match, and some of the recipes that call for a fraction of a gram, sometimes not much more than a drop, it was fun times!
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
  25. #21
    I used the RM system... it was based on volumes rather than weights like the Dupont system did (used that a bit too). You just watched the paint come up a sloped paddle until it hit the line and wasn't bad to work with. Tons of big binders full of paint codes before the phish cards came out. We were still using the base black for most black applications at that point, except for the Dodge Warlocks that had a black metallic. In order to make the metallics visible they had to add a ton of clear, and actually made the black a low hiding color so most of us shot a couple coats of base black first.
    Cut 50 Plasma
  26. Likes CAVEMANN liked this post
  27. #22
    Brethren, Mi
    Paint first coat one can, second another.
  28. #23
    Mar 2021
    Near Roanoke, VA
    Well, I JUST did this, three weeks ago,,,
    We wanted to paint a steel door, because 6 different carpenters refused to replace the door,, (brick on both sides!!??)
    My wife had picked a latex exterior paint, I decided to put a coat of tractor oil based paint on as a "primer"
    I thought,, heck, why not try to mix colors, and get the primer "close" to the final color that she wants??
    (I had the paints in the shop, left over from other projects)
    I mixed
    50% Allis Chalmers orange (Valspar paint)
    35% International Harvester Red(Majic paint)
    15% John Deere green(Rustoleum paint)
    I thinned it with a NAPA reducer, CR233 IIRC,,,
    and
    I added Majic brand hardener, at the recommended rate for Majic paint.
    I came within about 10% of the color of what my wife wants,, we may end up staying with this,, as I think the color is appealing more to her, every day.
    The paint is perfect,, it hardened within 3 hours, I re-hung the door the same day I painted it.
    I see no problem with mixing different enamel paints, even different brands.
  29. #24
    May 2007
    normally i wouldnt like that look/color. but w/ the backgrounds (bricks/floor) color, it looks really good. maybe the windows wood trim/dividers would look good white (like door frame). i paint alot of my steel welding tools/hammers/bars/etc "allis chalmers orange", w/ white handles.
  30. #25
    Mar 2021
    Near Roanoke, VA
    We have not even washed the trim,, yet,, let alone decided on a color.
    My 32 year old daughter has a real eye for such things,,
    When she saw the door, her idea was to follow the current trend,, - paint the trim "chocolate brown",,,
    That is a color we had not thought about, but, it is something I might put on,, to see if we like it.
    I will brush the trim, rather than spray like I did to the door,,
    Hopefully, the hardener will get me the high gloss like the door.
    brushed paint is usually not high gloss,, but, that hardener is magic when it comes to gloss.
Page generated in 1,635,101,265.89444 seconds with 13 queries
