HF plasma cutter problems.
I have a 40A HF plasma cutter. When i first got it it worked fine, cut 8 ft of 1/8 th steel. Went back today to cut out some 3/16 ths steel and it wont work right. Only cuts for a second then suts down. Nothing changed on set up. This is a new machine.
Re: HF plasma cutter problems.
---Meltedmetal
Originally Posted by
Meltedmetal
Check your ground.
Ground is good. Not getting enough air to cut clear through. Tried to reset air and not getting enough to set. Compressor is not the problem either. May be gun?
It came from Harbor Freight.... take it back to add to their collection of items that don't work...
Boatracer96
Same issiue .I got bigger air compressor .mine worked
check your consumables on the torch. IF you don't have plenty of clean DRY air, the consumables will go to hell real quik.
