Results 1 to 5 of 5
Thread: tweco 211i upgraded gun
    I'm shopping for a new mig gun for my 211i. I'd like a 15' cable. I'm getting confused on which ones will fit my welder. Been looking at the benards. Can anyone point me in the right direction or share a link to one? Thanks
    Jun 2008
    Re: tweco 211i upgraded gun
    I put a Lincoln magnum 200 on mine.https://bakersgas.com/products/linco...035-045-k497-1
    Or you can get the Magnum Pro 200 https://bakersgas.com/products/lincoln-k2950-2; different consumables with a screw on nozzle instead of slip on. Or you can get a pro gooseneck to convert the older one later. Nice lightweight gun, smoother feeding and the 15' reach is great! Use this back end https://bakersgas.com/products/linco...adapted-k466-2
    Cut the two lead wires and put some female spade connectors onto them, them they will plug into the gun. That backend will also fit powermigs and Vulcans as well.
    After using a multimatic with a Bernard gun, I might go that route too, but I don't have knowledge if you choose that path. I chose the Magnum because it was the best deal I could find 5 years ago. But the Magnum (and Pros) do fit nicely in My hand anyway.
    Does the adapter take place of the guns backend or go between it and the machine?
    Jan 2005
    Just a tweco 2/4 back-end for the Thermal. Just the back pin is different between the different setups.. The older style gun is just standard #14 tweco ft. end, and generally way more available then anything Lincoln sells for the pro.. It really is a great gun overall .
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
    Just ordered the magnum 200 and connector kit. Thanks for the help.
Page generated in 1,632,148,418.39612 seconds with 13 queries
