Results 1 to 5 of 5
Thread: tweco 211i upgraded gun
    I'm shopping for a new mig gun for my 211i. I'd like a 15' cable. I'm getting confused on which ones will fit my welder. Been looking at the benards. Can anyone point me in the right direction or share a link to one? Thanks
    Jun 2008
    Re: tweco 211i upgraded gun
    I put a Lincoln magnum 200 on mine.https://bakersgas.com/products/linco...035-045-k497-1
    Or you can get the Magnum Pro 200 https://bakersgas.com/products/lincoln-k2950-2; different consumables with a screw on nozzle instead of slip on. Or you can get a pro gooseneck to convert the older one later. Nice lightweight gun, smoother feeding and the 15' reach is great! Use this back end https://bakersgas.com/products/linco...adapted-k466-2
    Cut the two lead wires and put some female spade connectors onto them, them they will plug into the gun. That backend will also fit powermigs and Vulcans as well.
    After using a multimatic with a Bernard gun, I might go that route too, but I don't have knowledge if you choose that path. I chose the Magnum because it was the best deal I could find 5 years ago. But the Magnum (and Pros) do fit nicely in My hand anyway.
    Does the adapter take place of the guns backend or go between it and the machine?
    Jan 2005
    Just a tweco 2/4 back-end for the Thermal. Just the back pin is different between the different setups.. The older style gun is just standard #14 tweco ft. end, and generally way more available then anything Lincoln sells for the pro.. It really is a great gun overall .
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    Just ordered the magnum 200 and connector kit. Thanks for the help.
Page generated in 1,713,247,412.13789 seconds with 18 queries
