Results 1 to 8 of 8
Thread: Millermatic 35 s mig equipment does not regulate wire speed
    Jun 2021
    good afternoon I have an old miller millermatic 35 s equipment that does not regulate the speed of the wire everything works fine only the wire comes out a lot from the nozzle I need your help thanks.
    Re: Millermatic 35 s mig equipment does not regulate wire speed
    The wire speed control doesn't do anything and the wire comes out at the fastest speed no matter where it's set or the wire comes out without the trigger pulled, etc.? You need to give more specific details when looking for solutions to your problem. I'd guess you need a new rheostat or what ever controls the wire speed but I don't know all the details. You can look up the serial number on Millers site that may have some info under troubleshooting.
    Jun 2021
    the wire cable comes out at the fastest speed no matter if I regulate it at the minimum or maximum speed but in the power points 1-2 it can be adjusted in the 3-4-5-6 it goes out to the maximum speed without being able regular
    Sep 2016
    Detroit, Michigan
    Can you post the serial number? It will help the experts look at the correct manual for your machine.
    http://mivise.com
    Everlast PowerTig 210EXT
  5. Likes farmall liked this post
    Jun 2021
    miller millermatic 35s serial number 71-582633 then upload images.
    Jun 2021
Size:  68.1 KBName:  1623810821448.jpg
  8. #7
    This welder is simple. There are no electronic controls.
    the motor control is just a rheostat across the motor and the welder output.
    Change the voltage tap and the motor speed changes. If motor is running at full speed then you have a short across the rheostat allowing full voltage to reach the motor. use an ohm meter and test the rheostat. it should read 1.5 ohms and it is rated 50 watts. I see you have the spot weld timer. If it is set in spot the wire speed is bypassed. and motor runs full speed.
  9. #8
    Jun 2021
    I'm going to check the rheostat and comment.
Page generated in 1,627,615,531.19506 seconds with 15 queries
