Results 1 to 14 of 14
Thread: Fencing question
    Fencing question
    Building a fence. The fence is 110 feet long it will be mounted atop a wall. The wall is pitched at 0.8 degrees or Approx 1 inch per 6 feet. A difference of approximately 1.5 ft drop over the run.
    It this pitch significant and visible in fencing. The panels are 6 ft built square. Question: Should I stagger them an inch or run the panels even across the top.
    The pitch in not visible when looking at the wall.
    Re: Fencing question
    I see sound barrier fences along freeways and to me they look stupid because they will have maybe 20ft. at one height and then the next 20ft. at a lower height to follow the ground. It's personal preference but I think the top following the ground and being smooth would look better. On your fence, if it isn't noticeable looking at the wall, maybe you could make the fence so it corrects the drop/pitch and is horizontal across the entire length?
    Sep 2005
    Cave Creek AZ
    Make it straight, nobody will notice an inch and a half in 110 feet.
    1.5 foot over 110 ft. Or .62 inch gap between the plumb vertical post and a horizontal top rail connection.
    This decision dictate the number / length of finished panel I install.
    I will get to experimenting.
    This is a recreation if some existing fencing. The existing fencing is old and ratty. May also get replaced.
    May 2007
    i think it would be noticable if its a typical fence of vert pickets spaced about 4". if top rail was 1.5 sq tube, i wouldnt bring every panel up 1" every 6'/panel, cuz i wouldnt like the .5" of horiz overlap look at all. if u brought up every other panel, a .5" alignment gap between horiz rails - that would look better i think. might even go more than two panels.. i wouldnt want to hang my own fence outa plumb/level, and have to look at it every day knowing, and have done it on purpose . even if i couldnt see, it, it'd bother me
    You cannot put a pipe clamp on a diagonal and make them into a parallelogram? That would fix everything.
    Sincerely,
    William McCormick
    I was wondering if it would form a natural parallelogram when it sags. I will set it up in my shop soon and see the difference.
  8. Likes William McCormick liked this post
  9. #8
  10. #9
    How did it go?
    Sincerely,
    William McCormick
  11. #10
    In the shop, no decernable visual difference. The bubble does touch the line when the rail is offset.
    Ultimately in was trying to determine the length panel I could preassemble and how/where to connect them without welding.
    Ironically this fence is around the corner from a gate I replaced years ago. Where some drunk took the gate danced with and laid out in the street with it, then disappeared with the gate. The gate was found about 3 yrs later in a neighbors tree.
    I guess next question is security bolts for concrete?
  12. Likes William McCormick liked this post
  13. #11
    May 2011
    Security bolts.... nah.... just use a stainless epoxy all thread in 1 hole and gall the nut. Best security you can get.
  14. #12
    I use a level, then stand back & look at it. In some cases it looks awful! I mounted a meter socket, & service riser on an old house 6" out of plumb in 10'. I first mounted it plumb, it looked terrible! I then mounted it parallel to the building corner, that was better but wrong! I settled for splitting the difference, It was best in that situation.
    A fence near level but straight wants to parallel the ground. If it traverses steep or a mixture of pitches, mount panels level, correct for grade at each post.
  15. Likes William McCormick liked this post
  16. #13
    Thanks. Should have results within the next week or two.
  17. #14
    Sounds like project 👍.
    You have fun keep the work and photos.
Page generated in 1,627,399,144.91619 seconds with 14 queries
