Results 1 to 4 of 4
Thread: Shelving units
    Dec 2015
    Shelving units
    Making shelving units for either side of the fireplace. One done welding and painted flat black. Just need to make the wood shelving.
    Made one error on the dimensions, when cutting the cross pieces i was thinking of the 1" inner stock not the 1 1/4" main tubing. The shelving now needs to be 16 1/2" so I can't get 3 out of a sheet of plywood. maybe instead of iron-on wood edge i will have to cut edge strips and glue.
    Sent from my SM-N960U using Tapatalk
  2. Likes LtBadd, psacustomcreations liked this post
  3. #2
    Sep 2015
    West coast of Florida
    Re: Shelving units
    Looks good!
    Richard
    Sep 2008
    Dalton, GA
    Re: Shelving units
    Easy and economical to band edges with 1/2” strip of hardwood (poplar, cherry) or clear southern pine. You can find molding or cut on table saw. You have to cover the edges anyway. Just glue and clamp, do not nail or you will likely be dealing with splitting.
    I just finished a set of storage cabinets for my daughter, going to paint shop this week.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Jan 2011
    W. Wisc
    Re: Shelving units
    I use a headless pinner (23 ga air nailer) to keep edging like this in place while clamping to set the glue. Keeps them from sliding around and basically invisible. But yes, gluing on edging will make up for the shortfall, and unless you were going for the industrial look you were at least going to do veneer on the edges. This isn't much more work, and it also makes for a much more durable edge, so I would do it on one edge and face it front.
    Nice shelf design. Post up photos of it installed when you are done.
    -Dave
Page generated in 1,627,397,500.77762 seconds with 12 queries
