You cut the liner back and use a jump liner for each gooseneck.
Got a ln25 pro recently. Just got a k126 pro gun, came w/ a 6" gooseneck. Pulled neck off, and liner extends out (unlike the orig k126), and is cut to length to run into 6" gooseneck. Pro Gooseneck also has like a diffuser b/t neck and tip. Question is, hows this work when I put a 7.5 or 12" gooseneck on the gun? Liner would be short 4.5 or 6 ", unless I'm missing somethiong. It would be crazy to have to replace the liner for diff length necks. I swap necks lengths all the time. The orig k126 liner stops in the handle near trigger just shy of goosenecks butt end, and those goosenecks have there own/independent liner. Called lincoln, the guy there so bad/waste of time, and so was my distrubutor. So here I am. Anyone use the pro squirt gun, and know? The only way I can think around changing liner for diff length goosenecks, if the longer necks had some kind of built in partial liners from tips end to make up difference. ??
I thought original K125 guns you couldn't change the liner. Might be worth calling Lincoln again and hopefully getting someone that knows. I think any space especially with a 12" gooseneck is asking for trouble. A jump liner like Bernard uses would be the best option short of a new liner for each gooseneck.
the orig k126, has a sleeve holding the liner centered under the socket the gooseneck seats in - everything is in align. the pro 126 dont have that sleeve, nor a practical way to make it. i found other things i dont like about it since. i got it cheap/used, ill hang it on the wall, and use the ln25 pro for mig/dual sh probabaly. the guy at lincoln that day, told me in a jive accent -"the 126 only uses one gooseneck". i thought someone here would have run into the gooseneck issue before. i been buying the profax 1260's, as they are copycat of the orig 126, they have replaceable liner, cost less, and very interchangeable parts friendly - i like them most
