Results 1 to 18 of 18
Thread: I made an Anvil
    Nov 2012
    North Port Florida
    I made an Anvil
    Tried to buy an anvil but not happening! At my customers Mine site I saw a defective impact hammer from a rock crusher, 4 of these are installed on a rotor and it spins super fast. Any way I cut it in two pieces and welded together using rods from Lincoln for Hadfieldmagenses. I cut this using a Carbon arc gouging torch. The holes I drilled with concrete bits on my Enco mill/drill, I probably used at least a 100 bucks worth of drill bits and took all day. The Anvil weighs #340 lbs and the Florida oak stump at least 100 lbs.Name:  IMG_1666.jpg
Size:  115.9 KBName:  IMG_1666.jpg
Size:  115.9 KBName:  IMG_1395.jpg
Size:  98.5 KBName:  IMG_1395.jpg
Size:  98.5 KBName:  IMG_1665.jpg
    It seemed like a good idea at the time!
    Re: I made an Anvil
    That's nice work. Most of that crusher stuff is high Manganese and will work harden well from impact.
  3. Likes welding1 liked this post
    Apr 2016
    CA
    Re: I made an Anvil
    that is huge. Looks like a real anvil to me. Good job.
  5. Likes welding1 liked this post
  6. #4
    Re: I made an Anvil
    Wow. Great job on the anvil. Very impressive !
  7. Likes welding1 liked this post
  8. #5
    Mar 2005
    Under a Rock
    Re: I made an Anvil
    Very Nice.
    Any pictures when you were cutting it or forming the horn?
    sounds like a tough job.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  9. Likes 12V71, welding1 liked this post
  10. #6
    Re: I made an Anvil
    Yep... I bet you added some new words to the Dictionary making that Hardy too. Nice work.
    Cut 50 Plasma
  11. Likes 12V71, welding1 liked this post
  12. #7
    Re: I made an Anvil
    Very nice work! I've wanted to do something similar for ages, but I don't think I could make an anvil that nice!
    How'd you turn the horn all nice and conical like that? Was the steel hard to grind?
  13. #8
    Nov 2012
    North Port Florida
    Re: I made an Anvil
    To answer the earlier questions about the horn and the hardy hole. I shaped the horn with a carbon arc gouging torch and the a 7" grinder and yeah its hard! The hardy hole I drilled the 4 corners with a 1/4" bit and the finnnaly a 1" bit in the center and cleaned it up with a carbide bur. I have about 100 hours in it! seems crazy and really freaked out some old timers when I told them what I was doing at my industrial park.
  14. Likes 12V71, Shootr, whtbaron liked this post
  15. #9
    Re: I made an Anvil
    Very impressive indeed and it has a patent! Being manganese steel I'd guess preheat would be a no no or preheat and/or welding would have to be kept under about 500 deg's.?
  16. #10
    May 2021
    Quiet Corner, CT
    Re: I made an Anvil
    That is truly Impressive! Very clean shaping on the horn. I would not have guessed it was done with a handheld grinder.
  17. #11
    Re: I made an Anvil
    I've done build up work on manganese crusher jaws, believe it or not a severe water quench will soften mang, we would run a few beads and and cool it with water to prevent cracking. It's weird stuff.
    As far as work hardening goes, I showed a guy once that you could go to the corner of a jaw and put a huge divot in with a center punch. But if you beat on the same spot with a hammer and tried the punch again it would flatten the tip of the punch. Heat and quench and it was soft again.
  18. #12
    Nov 2012
    North Port Florida
    Re: I made an Anvil
    I did pre heat it, that was a trip. basically made a ring about 30" filled it with Kingsford briquets put the 2 pieces in there and covers with another bag and let it preheat. Every bead I ran had to be peened with an pneumatic impact, just as soon as the slag peeled off. If I didn't peen it it would crack almost immediately. I made this in 2012 and looks so cool in the shop!
  19. #13
    Re: I made an Anvil
    What are it’s dimensions?
  20. #14
    Dec 2014
    Northern California
    Re: I made an Anvil
    I’ll give you 100 bucks for it…
    That looks like it was a lot of work…should serve you well for years…
  21. Likes welding1 liked this post
  22. #15
    Mar 2008
    Georgetown, Texas
    Re: I made an Anvil
    Really nice job on the anvil.
    Manganese doesn't work harden, it work toughens.
  23. #16
    Nov 2012
    North Port Florida
    Re: I made an Anvil
    It's 25 1/2" long, 5" wide by 13" tall and weighs about 340 lbs.
  24. Likes Lis2323 liked this post
  25. #17
    Outside of Raleigh, NC
    Re: I made an Anvil
    That is extremely well crafted! My hat's off to you sir.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  26. Likes Lis2323 liked this post
  27. #18
    Apr 2014
    MN/WI
    Re: I made an Anvil
    welding1, you are like a chainsaw artist except you sculpt with a carbon arc gouging torch
    Lincoln Idealarc TIG-300
  28. Likes whtbaron, Lis2323 liked this post
Page generated in 1,632,510,227.71268 seconds with 13 queries
