Results 1 to 21 of 21
Thread: 4 1/2 grinder uses.
    Feb 2019
    Snyder TX
    4 1/2 grinder uses.
    Found a new use for an angle grinder!
    Feb 2019
    Snyder TX
    Re: 4 1/2 grinder uses.
    Oh yeah, Don't try this at home.
    Chain seems to be spinning fairly fast... wonder how the speeds compare?
    Cut 50 Plasma
    Mar 2005
    Under a Rock
    Chain is dangerously loose.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  5. Likes whtbaron liked this post
  6. #5
    Most of his tacks are suspect! Barely, if at all fused on one side. That could be pretty scary if something let go.
  7. Likes CAVEMANN liked this post
  8. #6
    Sebeka and Bemidji MN
    Terrible idea in my opinion...
    Special award for the locked-on switch so that if anything bad happens it stays running wide open...
    Syncro 350
  9. #7
    Apr 2016
    Nice loose chain. One nail in one piece of wood and I wonder where that chain will wrap around...
  10. Likes CAVEMANN liked this post
  11. #8
    Aug 2012
    AR
    Darwin's Theory about to be applied to the operator of that fab disaster.....
  12. Likes CAVEMANN liked this post
  13. #9
    Sep 2005
    Cave Creek AZ
    I think you can buy a new electric at HoDe for less than the investment in this Darwin saw.
  14. Likes whtbaron, Weldalittle, CAVEMANN, Broccoli1 liked this post
  15. #10
    Mar 2008
    Georgetown, Texas
    After seeing him stick and wire weld, I wonder if he thinks that is the correct way to weld every thing.
  16. Likes CAVEMANN liked this post
  17. #11
    May 2010
    ct.
    I don’t think I’ll ever need to turn a grinder into a
    chainsaw.Only good use I’ve ever had for an electric
    chainsaw was cutting up dunnage for rigging/ moving
    projects in a mill.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  18. #12
    They'd work pretty good for cutting a carcass in half if you could get a fine enough chain. I didn't like the bone fragments it left in the pork chops so I went back to the recip saw.
    Cut 50 Plasma
  19. Likes CAVEMANN liked this post
  20. #13
    Laredo, Tx
    Well, time to let him know gently through peaceful commentary.
  21. #14
    Apr 2014
    MN/WI
    The chainsaw disc for grinders is scary enough. I really could use one to remove bark from slabs and projects, but arthritis has weakened my grip. Have had the grinder with just a regular grinding wheel come out of my hands a time or two. Will stay away from anything with blades on a grinder.
    Lincoln Idealarc TIG-300
  22. Likes CAVEMANN liked this post
  23. #15
    Jun 2017
    AJO, ARIZONA
    Pretty sure that 4 1/2 " grinder runs 3000-4000 rpms faster than a 2 stroke chainsaw, that alone is unsafe, then factor in the loose chain. But hey, at least he had an automatic oiler! I think he should incorporate some buckin' teeth into that chain gaurd.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety. BENJAMIN FRANKLIN
  24. #16
    Jun 2008
    Watch at 8:02 of this video, not much makes me cringe but this did, .
    If you want to hear him describe it even tho it is a serious injury, he describes it in an entertaining if not macabre way and take full ownership of the way it happened.........Mike
  25. #17
    Quote Originally Posted by mrmikey View Post
    Definitely how NOT to hold an angle grinder...yikes
    Syncro 350
  26. Likes Welder Dave liked this post
  27. #18
    Apr 2018
    I might have missed it, but I completely disagree with his assessment of the cause of the accident. He should have repositioned his workpiece so that an unexpected catch or jump of the tool would not place his body in the line of fire.
    I am just as likely as anyone to become complacent in the shop, but receiving industrial safety training throughout my career has definitely prevented me from doing some things that would have gotten hurt just due to a lack of knowing ahead of time.
  28. #19
    Jun 2008
    ....but I completely disagree with his assessment of the cause of the accident. He should have repositioned his workpiece so that an unexpected catch or jump of the tool would not place his body in the line of fire.
    Yup, I agree. Should have been holding it so it goes away from him should it catch.
    Same principal as a kickback on a chain saw. you hold a chainsaw so the tip is just on the underside of a vertical cut or piece, it has no choice but to come back toward you, when it digs in the distance shortens, pushes against you and up it goes, it has to go somewhere.
    Didn't explain that the best but I know what I mean LOL..................Mike
  29. #20
    Mar 2005
    Under a Rock
    Quote Originally Posted by txpitdog View Post
    Yep,
    A drill press will ruin your day also...
    Position the drill vice or work so it catches the post if it grabs and spins..... instead of taking your hand off.
    Hypertherm PM 45
    HTP 221
  30. Likes MinnesotaDave liked this post
  31. #21
    Apr 2016
    my dad used to scold me as a child for leaving planes like that.....
Page generated in 1,632,409,954.82348 seconds with 12 queries
