Results 1 to 2 of 2
Thread: Trailblazer 325 arc reach question
    Oct 2016
    Like the title says, I have an issue with my trailblazer 325. When using the extreme 12vs arc reach feeder, which isn't often, I believe it used to stay at idle until you strike an arc then it idled down while welding. Had to get a new board in the feeder and now the tb325 runs at high rpm and only kicks down once welding. Does that seem right? Like I said, i dont use the feeder often, maybe a few times a year to weld 18g door jambs together.
    Oct 2016
    Re: Trailblazer 325 arc reach question
    Had a chance to mess with the machine today. Found out it was my mg remote base being hooked up causing the rpms to remain high. Glad that's all it was.
Page generated in 1,713,305,063.83851 seconds with 18 queries
