Results 1 to 23 of 23
Thread: building aluminum ramps from channel
    Mar 2004
    hueytown, ala
    I'm asking this question in several places, hopefully to find someone who can give me a definitive answer. So if you saw it on another board, excuse me for multiple posts
    I'm thinking about using aluminum channel for a set of ramps for my car hauler. My truck is very low and my 4' steel ramps don't give me a good approach angle. I cobbled together some 2x12s and a wooden stand to add to the length but its a pain to set it all up. So I'l like to build some longer ramps to change the angle and the aluminum is certainly lighter than anything I could build from steel. The cost of commercial aluminum ramps doesn't fit in my budget. Also I'm old and want something lighter to deal with.
    I have some channel that is 'available' to me It is 10" wide with .50 web thickness and almost 3" flange... about 15# per ft. The ramps will be 7-8' long .. and will go from ground to 17" high trailer deck... truck weight is 5300 +/- with front end weighting 3840. I can't find a table telling me weight capacity of channel with the load traveling up the wide web... like this any ideas on capacity ??
    any help appreciated
    john
    May 2011
    Re: building aluminum ramps from channel
    Alum channel will never hold up to that abuse. It is not ment to withstand pressures in that direction.
    Your best bet is to change it out to a double 4" heavy channel with cross members welded like a normal ramp is made. Then lay a piece of alum diamond plate or wood in it if you want it solid.
    Why do you need it on such a slight angle as the beaver tail has a much greater angle to it?
  3. Likes jniolon liked this post
    Mar 2004
    hueytown, ala
    thanks for the reply, my sketch is probably misleading... I want to maintain the same angle as the beaver tail (5 degrees) My truck is low 7-8" off the ground at the front valance and I need that shallow angle. My other objective is to keep the weight down... I'm old with bad shoulders and wrangling those heavy steel ramps is difficult.. plus I had access to the channel.
    When you say 4" heavy channel are you talking about steel or aluminum ?? I can see the weight adding up quickly as you add length with steel material.
    May 2011
    Alum channel
  6. #5
    Jan 2013
    Burnsville MN
    Based on information given I would recommend not exceeding 58 inches in length with that channel. If that length ramp works with the truck going on the trailer, the channel is as described, and the connection to the trailer is strong enough you should not have excessive deflection in the ramps. Shorter would give you a better margin of safety.
    If the ramp must be 84 inches long or longer you will exceed the recommended deflection ratio of length/360 for a live load. So in that case you should not use this channel without adding a center support of some kind.
    Obviously, if you proceed with this project you are assuming all the risks to life and property that come with fabricating your own critical structures. Don't even try to use this material at 7 to 8 feet in length.
  7. #6
    Personally I would block the ramps up in the center and use it. That effectively cuts your span in half and will greatly increase your weight capacity. That would make for a much better light weight solution than some heavy fabricated monstrosity.
  8. #7
    Maybe you could have some flip down supports half way up the aluminum ramps so they don't bend.
  9. #8
    Mar 2004
    hueytown, ala
    I like the idea of the center supports and it would add to the capacity of the channel... I've still got to get the trailer set up level and do some measuring for the length to make sure . I looked in to Race Ramps ( too $$$) and they recommended a 7' ramp to get the proper angle of approach... also Discount Ramp was in the same ball park, but I want to put an inclinometer and tape on it to verify. Also thinking of adding jacks on the back of the trailer to steady things while loading and keep the butt end of the tow vehicle on the ground
    thanks for all in input guys, I'll update as I move forward
    john
  10. #9
    Mar 2021
    Near Roanoke, VA
    WAY easier than trying to design long ramps out of available material,, you can instead practice looking for loading locations that give you an advantage.
    VERY little of this planet is flat,, with a little practice, you can get into a habit of looking for "LOAD-FRIENDLY" locations.
    It does not take much of a variation in location to give you a BIG advantage in loading.
    If you demand that your trailer be able to be loaded anywhere that you happen to drop the ramps, then even the length of ramp you stated will be inadequate,, so you are already partly looking for good loading spots.
    I have a dump trailer, and LONG ramps,, people are always shocked when I raise the dump body a little to give me a loading advantage.
    WHAT? do they think I am cheating,, or something??
    That might be an easier solution for you. Buy a small 12 volt hydraulic pump, and a cylinder.
    Use the pump and cylinder to create a hydraulic "foot" at the front of the trailer.
    The hydraulics would raise the front of the trailer (and the back of the truck) slightly, and this would result in the back of the trailer being much lower.
    There is always more than one way to skin a cat.
    I know if I did not have a dump trailer,, and only had a flatbed trailer,, the FIRST thing I would do is fab a hydraulic assist to raise the front of the trailer.
    When the rear of the trailer is lower,, loading ALWAYS becomes MUCH safer.
  11. #10
    Sep 2005
    Cave Creek AZ
    Just remember, when you weld in the center of your span you turn your T-6 channel into T-0 in the HAZ.
  12. #11
    Mar 2004
    hueytown, ala
    walker... I think that's above my pay grade... I don't know what t-6 to t-0 stuff means
    j
  13. #12
    Mar 2004
    hueytown, ala
    SweetMK, I already look for 'friendly' locations... this is a semi-show truck and It will be loaded and unloaded on asphalt or concrete and acceptable flat. so looking for a dirt bank other areas won't be done. I do already jack up the front of the trailer (and the back of the truck) with the front jack, to the point of almost getting the tow vehicle rear wheels off the ground, so I know that works with my cobbled together ramp solution... I'm trying to find an easier and lighter permanent solution that an old guy like me doesn't work himself to death loading/unloading
    here's the ride Name:  Img_0260.jpg
  14. #13
    Quote Originally Posted by jniolon View Post
    j
    It refers to the heat treatment that was originally done on the aluminum after extrusion. The heat from welding will remove the effects from the heat treatment, thus weakening the aluminum and reducing it's capacity to resist flexing or bending. You could bolt the supports on or better yet just block the ramp in the center to reduce flexing.
  15. #14
    Mar 2004
    hueytown, ala
    MJD, that was my original idea, just add some bolted on legs at the center of the ramp, or fab up a support block to stick up under the ramp
  16. #15
    Yeah, problem solved. If you are going to weld a hook on the trailer end, makes sure it's in compression rather than tension and you will be fine.
  17. Dislikes motolife313 disliked this post
  18. #16
    Feb 2019
    Snyder TX
    I have stiffened channel (steel though) for loading in the flat position by standing strap on edge inside the web in an X pattern. Skip weld 2 in 6 on the channel web, & weld all the junctions on the strap & flange. I don't know if it will work on Al though. May affect the heat treat?
  19. #17
    Sep 2005
    Cave Creek AZ
    FWIW, a tilt deck trailer makes your situation super easy!
  20. #18
    Jun 2016
    i think if you weld your ramps the way you want and block the center, you will be fine. that truck isn't that heavy for those centered blocked ramps. use old blocks of varying thicknes. oak works the best. try another similar weight vehicle that heavier first.
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
  21. #19
    Maybe a scissor jack like they use for levelling RV's would be an easy solution. Nice truck by the way.
  22. #20
    Mar 2004
    hueytown, ala
    thanks Walker
    When you're ready to bring it or ship it I'll give you address for delivery...what a nice gesture !!!
  23. #21
    Sep 2005
    Cave Creek AZ
    thanks Walker
    I’ll ship just as soon as your check clears.
  24. #22
    Sep 2005
    Cave Creek AZ
    Something else that can help with your current setup is to simply leave the trailer connected and drop the tongue jack and raise the front of the trailer up a wee bit.
  25. #23
    Mar 2004
    hueytown, ala
Page generated in 1,632,193,200.38278 seconds with 13 queries
