Page 1 of 3 123 LastLast
Results 1 to 25 of 69
Thread: How do I fix/remove these pathetic welds?
    Jan 2015
    Lewis Center/Powell Ohio
    I'm repairing/upgrading a welder stand that was given to me. Not my welds. Considering that these awful things are in/near corners, how do I remove them so I can put down good welds? The stock is 1/4" angle. Saving the stand for scrap and building a new one is not really an option right now.
    I could weld the open areas in the top 2 but the bottom one needs to come out because I have to weld a piece of angle right where it is. There may be other welds that need to be fixed, I haven't checked thoroughly yet.
    Only thing I can think of is some kind of tapered burr on my die grinder. If that's the answer, what burr?
    Or is there a better way?
    Aug 2018
    'ta town, KS
    Re: How do I fix/remove these pathetic welds?
    Can you use a cutting wheel? I would cut it ehith the wheel and burr as little as possible but I think that may be the best way. Open for other options
    Mac
    Fredericksburg, VA
    Hit the first two with a chisel and hammer. Put the chisel tip right at the bottom of the weld. It looks like there is no fusion so it may pop off.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Jan 2015
    Even a small Dremel cutting wheel won't get all the way in.
    If a carbide bur is the best answer for the bottom one:
    1) Which one for speed, there are a bunch of types and styles
    2) How do you deal with the tiny metal shards getting flung off and the chatter?
    The top two look like they'd even come off with a putty knife (exaggeration).
    If there is a weld on the back side of the ones in the first 2 pictures, cut it with a cutoff wheel, angle grinder , whatever you have and then take a pipe wrench and tip the angle towards the remaining weld. I don't think it will fight you much.
    ---Meltedmetal
  6. Likes bead-boy, CAVEMANN liked this post
  7. #6
    Mar 2021
    Near Roanoke, VA
    1/8" 7018, set the welder to about 160 amps, and weld over the existing welds,,
    The result will be beautiful, slightly oversize, ultra-strong welds,, that no one would question,,
  8. Likes Roert42, chewinggum liked this post
  9. #7
    I would use an air arc but people don't have one, a machine to run one or know how. Die grinder with a carbide Burr or a band sander
  10. Likes Zebidiah liked this post
  11. #8
    Mar 2021
    Near Roanoke, VA
    Think of this as "TIG" welding,, the 7018 is the tungsten,, the lousy welds are the filler metal,,
    Consuming the old welds with arc is by far the easiest approach, especially in corners,,
  12. Likes pepi liked this post
  13. #9
    A few of them look like you could break them off with your fingernail. Got a Popsickle stick or paint scraper?
  14. #10
    If just looking for strength, then i would not bother removing them. There is plenty of other areas to weld that could be ground and contoured.
    Otherwise thin and twist to remove parts. Or just twist.
  15. Likes 12V71 liked this post
  16. #11
    CT
    You are overthinking this IMHO. I wouldn't try to remove the old welds at all or even try to weld over them. In every one of those pictures, there were un-welded joints that you could zip up nice with your MIG welder or the stick rod of your choice. These joints don't need to be completely welded out for the weight a welding cart will hold. I would focus on the vertical joints, and just close those up nice.
    Miller Multimatic 255
  17. Likes 12V71, bead-boy, Kelvin liked this post
  18. #12
    But,but.but............. He won't get a good night's sleep for weeks cause he knows they are there.
    ---Meltedmetal
  19. Likes Roert42 liked this post
  20. #13
    Soda springs,Id
    And as usual nobody's mentioned the old tried and true scarfing tip.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  21. #14
    Jan 2015
    The top 2 are ugly but can be worked around. The bottom one needs to be removed, it's in the way. So I'll try MJD's suggestion of the carbide bur if I can find the right one. I think it will get into smaller places than a band sander.
    I would go with the scarfing tip but I don't have an OA setup.
  22. #15
    Aug 2018
    'ta town, KS
    A cutting wheel will allow you to cut what can and "V" it out to make decent welds. We had a welder at work who for the life of him couldn't get anything to wet in. He no longer works there but I used that method way too much for my preference.
    Mac
  23. #16
    This^^^^ Plenty of spots to put in some good weld.
  24. Likes bead-boy, Louie1961 liked this post
  25. #17
    Apr 2014
    MN/WI
    Yeah, the cost of burr bits and cutting wheels would almost exceed the cost of buying new steel and starting over.
    Lincoln Idealarc TIG-300
  26. Likes 12V71, TJS liked this post
  27. #18
    The tree shaped burr should get in there pretty good. Certainly not the fastest way to remove metal but they fit in areas where other things can.
  28. #19
    Dec 2012
    Woodstock, Ga
    Quote Originally Posted by JD1 View Post
    That's a given, the best you could do is back off the pressure slow the tool down. Chatter, slowing the tool also helps. Chatter is caused by fast, trying to remove to much material. Light cuts and many passes, adjust as you go.
    In other words there is no real answer, just realize the chatter is the tool digging in trying to take out to much material and bounces.
    Bull nose burr works well....
    Magazines have issues, everything else has problems
  29. #20
    Jul 2016
    Midwest
    Crank up the volts and burn a good new weld right next to them. Or use a chamfer electrode or cutting torch laid at an angle. Pretty basic stuff.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  30. #21
    Mar 2005
    Under a Rock
    Quote Originally Posted by bead-boy View Post
    Not to mention disfiguring yourself or bleeding out with the chinese death wheel when it blows up and you eat it.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  31. Likes Louie1961 liked this post
  32. #22
    CT
    LMAO...best laugh of the week. Thanks John!
  33. #23
    Use them as a template, and cope joints. The reassemble it in one plane.
  34. Likes Welder Dave liked this post
  35. #24
    Sep 2005
    Cave Creek AZ
    I would bet that you could put a 12” Crescent on those pieces of angle and twist them right out of the weld.
  36. #25
    Laredo + Midland/Odessa
    Plasma cutter set to gouging. If no gouging mode, set to very low amperage in cutting mode and run the plasma arc over it with a slight weave motion, and it will sorta-gouge it out.
  37. Likes filetobeef liked this post
Page generated in 1,713,253,299.99653 seconds with 20 queries
