Results 1 to 25 of 33
Thread: Winch mount. Feedback welcomed
    Apr 2020
    CT
    Hi all, Iím just a newbie welder and have mostly been playing around with sheet metal repair in cars. But Iíve been attempting to tackle larger projects and would appreciate some feedback as Iíd like to improve. I have a Hobart 210mvp and with this project I used .030 wire and always use C25 gas. My biggest problem is seeing beyond the puddle. I have a Miller auto darkening helmet but I just canít seem to ever get it set right. It makes it hard to do a long continuous Straight bead when your basically blind. Anyways, I think some of these welds came out good but I struggled on the corners. Any tips you guys could give me based on these pics? Any feedback would be appreciated. Great site btw.
Size:  203.3 KBName:  80D0AF57-8BBF-47CD-9C13-4C9AEA87F0DD.jpg
Size:  179.4 KBName:  3C021235-5926-4777-A669-C40B69E46887.jpg
Size:  182.3 KBName:  2A622694-BBE1-4E47-9F95-01E1DB2D6C7D.jpg
Size:  177.9 KBName:  A90B9B7F-9B3A-4A11-8933-B9095B964AAB.jpg
    Apr 2020
    CT
    Re: Winch mount. Feedback welcomed
    Here’s some closeup shots of a few of those welds.
Size:  96.2 KBName:  9A0CF65F-0372-4688-B4F1-4E1B92813910.jpg
Size:  94.4 KBName:  8201E90E-DD27-4878-BB1A-DF698D8AD08D.jpg
Size:  90.8 KBName:  F5D0BAB0-B17C-4E97-A338-9E8DA938874B.jpg
    Sep 2005
    Cave Creek AZ
    Looks like it will work just fine. It looks as though you are getting good enough to start picking nits, so get your hood issue dealt with, go to your LWS and talk with them about it maybe. You you can see, then work on refining your welds a bit.
  4. Likes Gxjetmech liked this post
    Apr 2020
    CT
    Thanks
  6. #5
    Los Angeles
    Just more time under the hood. It takes a bit to get used to.
    I like my shade light- 8-9 and lots of ambient light for me.
    I'll set up a work light to illuminate the welding area.
    Outside is fine but you can get sunlight coming in through the back of the hood and glare off the inside of the lens.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  7. Likes Gxjetmech, whtbaron, greenbuggy liked this post
  8. #6
    Apr 2020
    CT
    Thanks I’ll try that. I’m ready to toss this helmet and try another.
  9. #7
    Are sure you helmet is darkening?
  10. #8
    NW New Jersey
    Good prep job, mig welds don't always punch through mill scale well. Welds should be sufficient. Why not diamond plate ? Everything else seems to be. Just kidding, looks great. Really looks like a heavy duty winch.
    As to not seeing where you are going, are you pushing, or pulling the weld. When pushing the weld its usually easier to see the puddle and joint/seam.
    good luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  11. #9
    Apr 2020
    CT
    Yes it does darken. I’ve tried different settings but just can’t seem to get it just right. Like I said I’m going to try a different one and see how that works.
  12. #10
    Apr 2020
    CT
    good luck
    Thanks. Glad to hear the welds are decent. Generally I like to pull the puddle if I can. I’ll try pushing it and see if that helps.
  13. #11
    Quote Originally Posted by Gxjetmech View Post
    Yes it does darken. Iíve tried different settings but just canít seem to get it just right. Like I said Iím going to try a different one and see how that works.
    Go to local welding supplier and see if they have helmets you can test. The headgear can make a difference on fit and adjustments available.
    The better quality helmets are expensive. I feel they are worth the money. I'm still using my Miller Elite that's at least 10 years old.
    I'm considering the Miller ClearLight or Lincoln Viking. I never did considered a cheap auto darking. $300 isn't bad when you get 10 years out of one.
  14. Likes Gxjetmech, whtbaron liked this post
  15. #12
    Soda springs,Id
    Nice build!! When you make your first hard pull hold a square against the front channel you added to see if it flexes any. If so maybe add some gussets to each side of it.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  16. Likes Gxjetmech liked this post
  17. #13
    Your welds look good.
    When you say"basically blind" what ya mean? Is it an physical ailment or shade too light or too dark?. Or are you in the way?
  18. #14
    May 2007
    theres a lil room for improvement/placement of the craters, but i like it, cuz u didnt overweld it. sometimes new guys, put too much weld on things
  19. Likes Gxjetmech liked this post
  20. #15
    Apr 2020
    CT
    I just can’t see much beyond the puddle and before I know it I’m welding off the joint sometimes. Maybe I just need to play with the shade settings some more. Lighten it up some. I’m going to give it a try tomorrow and see if I can’t get this corrected. Because it definitely effects the way I weld and not in a good way.
  21. Likes BD1 liked this post
  22. #16
    Apr 2020
    CT
    Thanks for all the feedback guys. Iím glad to hear the welds look ok. Iíd hate to use the winch and have a weld fail in the middle of the pull. Iíve just read up on welding a little and just kind of wung it. So its good to get some critiques, good or bad.
  23. #17
    I just canít see much beyond the puddle and before I know it Iím welding off the joint sometimes. Maybe I just need to play with the shade settings some more. Lighten it up some. Iím going to give it a try tomorrow and see if I canít get this corrected. Because it definitely effects the way I weld and not in a good way.
    Check out video's on Welding hoods filmed through the hood. The shade tint, viewing area, all affect how well you see.
    Setup a halogen light or better yet, a photography light is great.
    Try to position the light for best viewing. That can be tough to do.
    Depending on your hood, lights are available to attach to them.
    https://www.millerwelds.com/products/helmetlighting
    Making a line with soapstone or white pipe marker will help as a guide. There are a variety of markers available.
    Here's a Miller one
  24. Likes Gxjetmech, whtbaron liked this post
  25. #18
    Apr 2020
    CT
    I have tried using some additional light on the joint which definitely helped. I just went out and looked at my helmet, it’s a Miller Digital Elite. The problem I have is that on the lightest setting (8) It’s still to dark. Maybe I should try a different mode? Thanks for those tips tho. I’ll try those as well.
  26. #19
    Soda springs,Id
    OK, I have to ask if you removed the plastic coating on the inside or outside of the lens.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  27. Likes robocow liked this post
  28. #20
    Apr 2020
    CT
    Lol, I did. I just pulled it all apart to make sure I didn’t do something like that.
  29. #21
    Soda springs,Id
    OK, it's happened to some others.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  30. #22
    The Miller lenses have a Blue pattern on the clear plastic. It has been done before.
  31. #23
    Looks like job.
    Basically the more you weld and fab the better you become.
  32. #24
    Mar 2021
    Near Roanoke, VA
    Are you over 40 years old? you may need a "cheater lens" inside your helmet.
    Go to a local pharmacy, and try the various power reading glasses, at the distance that you normally weld.
    Look at the glasses, it will have a magnification power listed (like 1.50,,, or 2.00 etc)
    You need to then acquire a cheater lens that is the same "power" as the reading glasses that you liked.
    It will be the best $5 to $10 you ever spent on welding equipment,,
    https://www.amazon.com/Cheater-Lens-...843577&sr=8-32
  33. Likes whtbaron, 12345678910 liked this post
  34. #25
    Apr 2020
    CT
    Ya I’m 54 and have bi focals. Ill try a set of cheaters, it’s worth a shot.
  35. Likes whtbaron liked this post
Page generated in 1,632,286,804.33457 seconds with 13 queries
