Results 1 to 15 of 15
Thread: Spray transfer mig torch angle
    Jul 2021
    Iím welding (multiple) 30 inch 2g t joint on 3/8 mild steel with ~3/8 toes. My company requires this weld to be run at 26v 280 wfs with 1.6 mm wire on 90 argon 10 co2. Iím running a straight push getting equal toes but canít seem to get it to fill in perfect. Any tips? My boss and the other welder donít have any advice and think the welds Iím putting are good, but I know they could be better.
    SoCal-LA
    Re: Spray transfer mig torch angle
    Quote Originally Posted by racecar616 View Post
    Why are you pushing????? Does your procedure require you to push? Depending on the power supply electrical characteristics pulling will get better penetration to the root and wet the toes better IMO. Only with alum or flux core would I push. Even then I pull sometimes when in a pinch.
    Apr 2021
    I'm confused - perhaps I need to retrain.
    Jack
    Mar 2012
    Australia
    I personally like to pull spray transfer slightly, not massively but by maybe 10 degree's, I find I get a nice bead profile that way, pushing usually gives me a slightly concave weld profile.
    Jul 2021
    So straight push Iím running perpendicular with maybe 5-10 degrees push because I found it to give me a way better better bead. I started out pulling and my toes werenít filling in and the bead was rolling over
    Jul 2021
    Iíll try that perhaps I was pulling at slightly too steep of an angle
    Apr 2021
    I'll be more specific with my query (not a disagreement or challenge). My query is based on curiosity more than anything.
    Going by the number of question marks, this is something you are passionate about. Many people are but I can't find any evidence that one is better than the other. Some of the weld, etch and tests - including one done by weld.com with Select-Arc - show no difference using MIG, spray, 1/2" plate & 2F.
    In the weld.com/Select-Arc test using flux core (FCAW-S), the Select-Arc fellow said that drag was recommended for that process (same context as for MIG). There were two reasons:
    1. There is a higher chance of slag inclusions but that is more a technique issue than a basic shortcoming.
    2. There was greater penetration.
    As far as I know (and my experience is not extensive), filler specification documents list typical applications, metallurgical data and positional data. There is nothing about pushing or pulling.
    There are a lot of parameters that will affect a weld so push or pull might go in and out of fashion depending on other factors but there does not appear to be any clear answer as to which is preferred.
    It seems to me that to say one is preferred over the other requires additional information like:
    - for what reason is it preferred?
    - in what context is it preferred?
    because what is preferred in one situation might be disastrous in another.
    Thanks
    Jack
    SoCal-LA
    2 things were discouraged when I was steel mig/arc trained in college. Pushing and downhill progression. Both can result in lack of fusion to the root and a concave weld profile, slag inclusions, and possible overlap in the toes. Sometimes you have to do it in a pinch but I hate it.
    However alum mig is always a spray arc process with smut being deposited in the root. Pushing lifts the smut out of the root and the coefficient of heat tranfer gives decent wetting at the toes. Pulling alum mig may bunch up the puddle causing due to the arc transfer from said puddle.
    That is the way I was trained, it works for me, and I stand by it faithfully.
  9. Likes scsmith42, Munkul liked this post
  10. #9
    Apr 2021
    Thanks for responding. As I noted earlier, I am just curious, I'm not selling anything.
    There is an old "rule of thumb" - if it creates slag, you drag. However, it seems you were trained to do the opposite.
    Welding downhill is another thing. Some are adamant that one should never weld downhill because it always causes lack of penetration. Other say with thin material or for a root pass it may be better to weld downhill to prevent blow-through. This is a variation of what I said in my previous post regarding what is appropriate in the circumstances.
    None of this causes me to lose sleep or be unable to weld but it does surprise me.
    Regards
    Jack
  11. #10
    Jan 2020
    Pushing and pulling are both acceptable techniques to used in GMAW spray transfer. Dragging creates deeper penetration but requires a higher skill level to operate. Pushing creates a more uniform weld profile with less chance of undercut. Both techniques are essential to learn but ultimately it is up to the employer on which one they want emphasized (if your not self employed).
    If we set up two 1/4" material thickness T-joints and used both methods.... which one would have superior penetration and profile? Well that would come down to who is doing the welding! In spray arc welding penetration should never be a problem. So is dragging therefore necessary? I was taught to push only, but have since realized that is complete nonsense.
    Lincoln 275 Squarewave
    Lincoln SP 250
  12. #11
    Apr 2021
    Quote Originally Posted by Zebidiah View Post
    I have no problem with that at all. The point that I was making is the the hard and fast rules should not exist as depending on the situation, it may be necessary to drag or to weld vertical down or some other sin. Each in its place so to speak. I think some of these rules come from early training where it is "safer" to do one thing over another. They should fade away with experience but that is not always the case.
    Of course some procedures (codes) require that things be done a certain way but that is a different kettle of fish.
    Regards
    Jack
  13. #12
    Jan 2020
    Quote Originally Posted by Jack Ryan View Post
    Regards
    Jack
    Agreed 100%. A lot of the hard and fast rules that welders hold dearly, actually started out somewhere as "shop rules". If you can't back up what your saying with AWS or similar code your just speaking to what you've been taught. Doesn't make it wrong, just incomplete.
    Whats acceptable in one shop is not the same as the next (often even within the same company). I cringe when I'm working with a welder that wants to argue about how he did a particular procedure at his last job. I usually reply with "your current employer wants it done this way". I'm all for discussing expectations. There is also a time and place to discuss deviations. However it is not before you know the rules well enough to break them. Thus "shop rules" are created ha ha.
    Lincoln SP 250
  14. Likes shovelon, Jack Ryan liked this post
  15. #13
    SoCal-LA
    There is a lot of truth to your statements. When it comes to GMAW, spray arc, dual shield, inner shield, or metal-core, short arc or spray, there is general shop welding, or steadfast production welding. General shop welding is more of a "Git-Er'-Done" scenario. Production can have many weldors performing the same welds at the same time, and they need to do it the same way. Usually the shop manager or lead man sets the routine and the pace, with constant deviator crew members shown the door. For instance right now I have an alum mig joint that actually lends itself to downhill drag in spray, and the whole crew performs it. This flies in the face of downhill and dragging in spray arc alum but we get the desired result.
    But then I am a tig guy, and my customers have on clue what backhand or backfeed is when it comes to tig, and they really don't care.
  16. #14
    One of the biggest wives tales is regarding the width of weave on vertical up on mild steel. A lot of places and weldors claim max. 3 electrode diameters, some 2 1/2 diameters. Wanting to get official clarification several years ago I sent an an e-mail to Walter Sperko who is one of the top people behind ASME codes. He said he would challenge ANY procedure that lists a maximum weave width on mild steel or common boiler plate. He also said more heat is better and as long as there are no slag inclusions you can weave as wide as you like. Somebody said something back in the 60's or whenever that wasn't based on anything but people take it as the gospel. Funny that I had e-mailed another weld qualification inspector who also said 3 times diameter. I think I'll I'll go by what one of the ASME code writers says. On stainless you want/need to limit weave width and heat input.
  17. #15
    Jul 2018
    Cumbria, UK
    The other thing to remember with weaving, is that you're massively increasing the heat input per pass, which can be a bad thing, especially on highly restrained joints or crack sensitive material.
    So there is a good reason for running stringers...
    As for torch angle, straight wire i was taught to push, no matter the transfer mode. Only a slight push angle. But it's OK to pull, too. Always got plenty penetration. If I pull, the weld bead goes too concave.
    Name:  2021-07-21 18.28.18.jpg
  18. Likes scsmith42 liked this post
Page generated in 1,631,982,541.07347 seconds with 13 queries
