Results 1 to 3 of 3
Thread: Short hood F-162 year?
    Oct 2013
    cntrl FL
    I have a 1945 Short hood with the F-162. It has a rebuild tag on the block from Lincoln Electric Date stamped "12-53", bored out 0.040, STD Main and Rod journals, with the serial # 31370. The engine block is also stamped 31370, but on the right side of the block has a date 1-16-Q. I called Montes Equipment and they said it was a 1965 engine. Doesn't really make since being that the rebuild tag has Dec 1953 on it.
    SA 200s : 1944 1945 1963 1965 1969
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Nov 2012
    ROCKVILLE ,,VA
    Re: Short hood F-162 year?
    found lot block dates on top head usually in center closes water neck near firing order,, may strip some paint
    Oct 2013
    cntrl FL
    Here is the head cast date: F-4-7 . I have tried to figure out that if F= June, 4th day, 7= 47 ?
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
Page generated in 1,632,224,831.39286 seconds with 12 queries
