Results 1 to 25 of 43
Thread: Annular Cutter Arbor
    May 2013
    South of Dallas
    I have a bunch of Hougen style bits that I would like to use on my drill press, Can someone tell me what size arbor I have so I can figure out the Annular Cutter Arbor I need?
Size:  31.7 KBName:  IMG_4514.jpg
    Aug 2018
    'ta town, KS
    Re: Annular Cutter Arbor
    Morse taper #4
    Mac
    Jan 2011
    Hutchinson Kansas
    Looks like a Morse taper #4 to me.
    http://www.davehylands.com/Machinist...aper-Chart.png
    Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
    May 2013
    South of Dallas
    Thanks guys
    Here's what they look like
  6. Likes Millwrightdude, whtbaron liked this post
  7. #6
    May 2013
    South of Dallas
    Mt4 to 3/4'' Weldon Shank?
  8. #7
    Quote Originally Posted by Millwrightdude View Post
    I will need to look later. Might be MT3
  9. #8
    May 2013
    South of Dallas
    I looked at the part diagram from my drill press, Its a MT3. This is what I think I need?
    https://www.amazon.com/Annular-Cutte...ustrial&sr=1-3
  10. #9
    Mine is MT3.
  11. #10
    Just make sure you have a large enough motor to turn 'em. I can't use annulars on my small press, not enough balz. My mill is the only thing that will run them well (1.5hp motor)
  12. Likes VaughnT liked this post
  13. #11
    May 2013
    South of Dallas
    My drill press is 1.5hp
  15. Likes farmersammm liked this post
  16. #13
    May 2013
    South of Dallas
    So will my drill press do it?
  17. #14
    You would need to be down in the 200 rpm range or less depending on hole size.
  18. #15
    That's what I prefer over a drill press. More rigidity in the spindle, better RPM selection and ability to clamp the work securely.
    I just use a 3/4" collet for the annular cutter.
    Oh and power feed!
  19. #16
    May 2011
    Hougen recommends 550 for bits up to 1 1/4" I believe.
    I run steel (up to 1 1/4) on 660 and stainless and large steel at 325 on my Bridgeport
  20. #17
    I think it will. Keep to the lowest RPM, and keep the belts tight. My greatest problem has always been belts slipping. Even the mill will slip if I forget to really put some strain on the belts.
  21. #18
    Here's a comprehensive speed/feed chart for annulars https://www.icscuttingtools.com/pdfs...ar-Cutters.pdf
    To me anyways, these are aspirational speeds on my machine. If I exceed 230rpm, the cutter will cut allright, but you have to be careful not to overload it while continuing to take material. Anything 1", and above, has a tendency to cause my belts to slip when the cutter starts to stall. And it's a Catch-22..............the cutter starts to stall because the belts start to slip I don't have the best machine, so it might not be representative of how your drill will handle the cutters.
  22. #19
    Here is a 1.5 HP drill press I had where I added a jack shaft to enable RPMs down to 150.
    With the reduction of speed it is even more critical than ever to have TIGHT belts as samm mentioned.
  23. Likes N2 Welding, whtbaron, VaughnT, scsmith42 liked this post
  24. #20
    Aug 2006
    St. Paul Park MN
    I use annular cutters up to 2 3/4"x 4" in a radial drill with coolant inducers and have always found it best to start below recommended speeds and feeds to get a feel for speeds and feeds that don't set up chatter.
  25. #21
    I use the cutters quite often in my dewalt 1622 magnetic drill. 2 speed gearbox, 300 and 450 rpm. Up to 7/8" or so I use high and then low for larger ones. Ive ran 1-3/4" cutters with it and had no chatter issues at that speed. I generally use cutting oil instead of coolant as most holes I punch are horizontal.
  26. #22
    May 2013
    South of Dallas
    Ive been thinking I might find a mag drill
  27. #23
    Sebeka and Bemidji MN
    I really love mine Have not tried the cutters in the vertical mill yet - but I might.
    Syncro 350
  28. Likes Lis2323 liked this post
  29. #24
    You won't be able to use pilot nor will the slug eject if you use a end mill holder.
  30. #25
    Yes. Good point
Page generated in 1,634,478,076.64085 seconds with 13 queries
