Results 1 to 14 of 14
Thread: pcm 875
    Jul 2021
    pcm 875
    Need to have this 3 phase to be able to run on single phase Info I have Believe machine was new in 2000 EN50192
    Can this motor be rewired (easily) to single phase by disconnecting Red wire and if so will #8 wire and 50 volt at 230 be sufficient? Or, do I need to buy a phase converter and if so how do I determine which one?
    Unit was only used for one or two small projects and then put aside.
    If you need more info from machine advise exactly what and will attempt to furnish.
    Jul 2021
    Re: pcm 875
    should have read 50 amp not 50 volt
    Jan 2011
    Hutchinson Kansas
    Re: pcm 875
    If I remember right they are made three phase or single phase and cant be switched
    Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
    Dec 2008
    Re: pcm 875
    I looked up the electrical schematic and it is 3 phase only.
    Jul 2021
    Re: pcm 875
    ESAB told me it could be done but they do not do it. If a need a phase inverter do you have any thoughts as to which one would work best and most reasonable. New to this field
    Dec 2008
    Re: pcm 875
    Here is the manual. https://www.esabna.com/literature/pl...f-15-424-a.pdf
    You could hook 230 volts to terminals 1 and 3 and it would power up but the fact that nowhere in the manual does it say ANYTHING about single phase
    I suspect that there are parts changes needed, at least the input rectifier, to deal with the different current draw!
    If it were my machine I would not do it!
    Get a phase converter!
    There are others on here that know ALOT more than I do about phase converters.
    Jul 2021
    Re: pcm 875
    Thanks for your reply Not getting any responses re phase converters That would be my preference but do not know enough to make the purchase. As i mentioned ESAB does not sell phase converters and I am at a loss as to which one to buy.
    Dec 2008
    Re: pcm 875
    I know there has been numerous discussions about rotary phase converters on here but a search didn't find much!
    Post a question about phase converters in the "electrical section".
    That's where all the sparkies hang out!
    Laredo + Midland/Odessa
    Re: pcm 875
    Quote Originally Posted by Harryvan View Post
    Post a picture of the actual electrical specification sticker on the machine. Let's start there.
    Ceres, California
    Re: pcm 875
    They made about 4 different versions of this plasma. 230,460 575 all 3 phase only.
    But they did make a 208/230 single phase unit. that also might be a 3 phase.
    Need to see a picture of the data plate. serial number and stock number.
    Then can give you a more direct answer if your plasma can run on single phase.
    Jul 2021
    Re: pcm 875
    P/N 36590 - 208/230 V, 1 & 3-Phase, 50/60 Hz
    P/N 36592 - 460 V, 3-Phase, 50/60 Hz
    P/N 36714 - 575 V, 3-Phase, 60 Hz
    P/N 36725 - 400 V, 3-Phase, 50/60 Hz
    Jul 2021
    Re: pcm 875
    I have great difficulty sending the plate picture as the site keeps telling me the file is too large. I am putting my personal email here. I will forward the file to anyone who thinks they can help me resolve which phase converter I need. Rollstone7@charter.net Thanks for any help
    Jul 2016
    Midwest
    Re: pcm 875
    That machine came either 3ph or 1ph. If I remember correctly you can not switch back and forth. Also the ESAB units from that Era didn't run well on 208v. Fot what you'd pay for a phase converter you can buy a 1/2" plasma that will run on 1ph, 115/230v. That is what I would suggest.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Ceres, California
    Re: pcm 875
    Check your camera settings you should be able to change the picture file size to a smaller one. 5 mega pixal should work just fine and the picture will be clear.
    Or convert the picture to a PDF picture on you computer before uploading.
Page generated in 1,713,291,381.32981 seconds with 18 queries
