Results 1 to 6 of 6
Thread: Linde V-160 manual
    Aug 2021
    Linde V-160 manual
    Hi, I just acquired a Linde V-160 Migmaster, serial number 138695. I'm looking for the manual (P/N L12-852). I found a few links on the web but they are incomplete, only 6 of the full 15 pages. The torch is missing so I'm wondering what would be a suitable replacement for the original MT-200 torch (P/N 948911) and the wire feeder connector (P/N 2075380) that came with it. I heard that these are great machines. Can't wait to use it. Any help will be greatly appreciated. Thank you.
    Re: Linde V-160 manual
    Call ESAB tech support. They should be able to give you a choice of a couple of tweco guns that will work on your welder. At one time they had a conversion kit so the MT200 could use a different type of consumables
    Tweco is part of the ESAB family of companies.
    Try going to ESABNA.com dig around in the download archives you might find a manual. Send me a PM if you can't find anything. I might have a paper copy I can scan. will have to look through 7 or 8 2inch binders of old manuals.
    Aug 2021
    I spent quite a bit of time searching through the ESAB support documents for the manual to no avail. If you could find yours and scan it I would greatly appreciate it. Maybe it can then be added to some support database here for others to use too. Thank you.
    will need you to send me your email by PRIVATE message.
    Make take me a day or two to find it and scan it.
    Esab tech support is usually pretty good if you get the right person. They will be able to tell which newer guns will work.
    Have the manual here at home just need to an email address to send it to.
    File to to large to post here. Use the private message, just click on my name.
Page generated in 1,635,284,846.85554 seconds with 13 queries
